oh, that sucks!!! So close....
I wish I could hook that up for my drive back home from Seattle but I suck at electrical work, plus I'm not detail oriented and I want a nice clean install.
Tell me a bit about the Nolden headlights. Is that an easy DIY upgrade?
Yeah, and with the fasteners on the ends even with the "bar" clamps, I don't think you could shorten the threads of the 2 fasteners enough to make it all clear.
There have to be PLENTY of good places in Cali, even skilled stereo shops, who can easily take care of this for you.
Yes, pretty straightforward. Drop down the bull bar w/ factory tool, remove the 4 fasteners on top of cowl which secure the grille, remove the 2 Phillips screws underneath each body-colored headlight surround, pull up driver and pass headlight surround, pull up on the grille, pull headlight surround tabs out from behind grille, remove headlight/bucket assembly, unclip 3 plastic clips which hold lamp to bucket assy, install Nolden lamp using supplied custom bracket/SS hardware, trim off their weatherpak connector for the "city" light bulb, install male/female spade connectors, plug in the lamps, re-install lamp/bucket assy into car, reassemble in reverse order from above. Can you tell I've done this at least a few times?
The issue with the Nolden's right now is that many of the Osram components for them are used for new vehicles, so large production runs need to be done to keep costs down, and of course there aren't THAT many G's who are looking to upgrade headlights, so we need to piggyback our order with another (Euro) companies' order due to the VERY low quantities requested in the USA. We have about 3-5 people interested and ready--trying to get to 10 people.
