The only elements that I can think of is mud / dirt that might get into the hole. I'm not worried about anything getting into it right now so there is no plan. If it becomes an issue I'll work on something to fix it.How have you decided to keep the spout protected from the elements? Some kind of door on hinge?
Thanks, the tank is from Front Runner, it's a 50 liter tank (13.2 gallons), W 1000mm (39.4") x H 350mm (13.8") x L tapered 200mm (7.9") to 150mm (5.9"), it is actually designed to go behind a seat but it worked out well for me.Sweet Water tank? Where did you get it? Dimensions? It looks like a really nice addition to an already sweet build!
Cheers!
I'll have my brother ring in on this he can give you the exact information. But the answer is yes we have changed things, it's a learning curve.Hi Crush since you and your brother are up to the 3rd generation did you change anything about the lid ?
What would you recommend material wise ? thickness,etc
Awesome fab skills.... learned a lot just looking at your photos!!
Jeff
Just a look at the latching system on the lid.
Here is a few close ups of the latch. Hope this helps out.Could you post a picture of the other half of the lid latch? I have some similar that failed on the way to the Overland Expo. Currently I am using ratchet straps to keep my lid closed.
Awesome builds!
What kind/source of water and fuel cans where you using before you switched to the tank? They look like something I could use for mounting on the front of my trailer similar to the way you had yours originally. I'm trying to keep things off the side if I can...if I can get the weight to work out in my favor that is...I might end up having to put them on the side further back
