richard310's 04 Xterra
richard310
pew pew
I would run them for a bit before you take oene out, they will settle a bit especially after you load them down this weekend
x2.
...but then option 3 ;)
Yeah I might end up doing that but i ordered the Calmini UCA's already. D'oh! If they come in tomorrow, I'm throwing them on. If the rear end settles after this weekend I'll readjust the front height.... if they don't come in before I leave, I'll hold off on the UCA's and see how much they really settle. I might just suck it up and do a 2" front end lift...
mortonm
All you would need is the new sway a way torsion bars, will give you enough clearance. Might not even need the UCAs
richard310
pew pew
So the UCA's are on backorder for 2 weeks. I really hate it when shops that are internet based don't update their freakin inventory. How do these places survive?!
Looks like I'll be driving with extreme rake for awhile. It looks really stupid. So stupid it's embarrassing.
Correct me if I'm wrong, but I believe we'd still need aftermarket UCA's as OEM arms can only articulate so much before you hit the bumpstops. Aftermarket units will give you the extra length and height even with OEM torsion bars + reindexing.
Cooper ST Maxx. Only $954 shipped from Tread Depot!!!!! DOOOOOO IIIITTTTTT! :D
Gah that's a chunk of change. I'm going to rock these BFG's until they're gone. Maybe some spacers in the meantime to get rid of the sunken battleships look.
mortonm
True, however you can get 2" without bump stop issues with stock UCAs.
Try cranking your stock t-bars ans see first how they respond. You will need new t-bars eventually anyways, they firm up the ride, but see how the stock will do for now for a temp fix
wreckdiver1321
Overlander
This.
I got 2" out of my first gen with all stock parts. Zero bottoming out issues.
richard310
pew pew
I'll give it a whirl tomorrow after work then. I've heard mixed stories regarding the torsion bar crank of people getting anywhere from 1" to 2", and also the loss of downward travel.
I took a look at my height right now and it is about 0.75" from the bumpstop to the UCA.
wreckdiver1321
Overlander
As long as you leave about 3/8" between the UCA and the bumpstop, you should be fine.
Longrange308
On your way home, stop by my house. You can crank on your Torsion Bars here and then help me install my new front bilstein lift shocks to match my new AAL's that I installed the other day. :friday:
Rake city over here too! LOL!
BTW.. Option 3 is always the best option, and I agree with the ST MAXX tires.. I Love mine, which are 33's.
richard310
pew pew
So I stopped by Longrange308's place and I find him about halfway installing one side. I lend a finger or two of help as there wasn't much I could do. Got started on getting the torsion bars cranked. Super easy and all nuts broke free effortlessly. Got the fronts raised up with about a 3/8" gap between the bumpstop and UCA gap actual. It sits a little more level, but still needs that extra inch to finish it off. It looks to be about a 1.5-2" increase
Of course I didn't measure it before I started... I'll have to pull a measurement from ground to fender well tomorrow and compare some notes.
