AA1PR’s Yukon Long Term Build & Adventure Videos 56K
AA1PR
Disabled Explorer
Sorry to hear about your jerk neighbor messing with your truck AA. What is his problem anyways? Maybe time to break out the firearms? Cool vid/pics and thanks for posting up!:)
NO no violence, I'm not stooping to his level, he has mental issues....
tried to solder the wore leads onto the old bulb socket for the new LED's , FAIL
so they're hard wired
was trying to figure out how to mount these, so after removing one of the units I just replaced last winter...
I came to the easiest conclusion that since I hated them & need a bracket to offset them off the bumper I'd cut the lower section(s) off, drill a 3/8" hole & mount them that way
orange square is about where I drilled
the hardest part is trying to angle these down, I followed the plastic valence for forward right/left alignment
AA1PR
Disabled Explorer
AA1PR
Disabled Explorer
hit a deer & took out the passenger side LED I had just installed hours before
OK finally the second set of LED's has finally arrived
the hardware appears the same
hooked them up to my power supply & they are blindingly bright, so time will tell
also added a heavy amount of liquid electrical over the wire connection on the back
also deciding where to mount these other than under the bumper in the stock location
AA1PR
Disabled Explorer
Jr (my son) put on the front receiver for me & I threw him some dead presidents for it
I had him flip it like Adam Bushcoat stated they did on his dad's, though he argued with me a bit over it, until he finally realized why
everything torqued to 110ftlbs
gonna put these back on when the weather gets warmer
since we had to remove the lower valence to get the receiver on I moved the LED's under the bumper, dont like them there & cant decide wheres a good safe spot & replaced the defective one too
sorry for the blurred pics but it was cold
AA1PR
Disabled Explorer
oops forgot I replaced the rear broken mount one with the new rectangle one
cant get the one with the wire ripped out of it apart to fix it, so I need to order more of these so they match
& I like the look better
rayra
I like the front mounted hitch. I also like that it's in a good spot to guard the front axle. I presume that's the same mounting location for aftermarket bull bars / grill guards, which might be a problem for me. Or require replacement of the mounting plates to accomodate both both structures, on my Suburban build.
HenryJ
Very cool hitch flip on the front. First I had seen that done. Super! Really improves the approach angle.
The custom from receiver I built sat just a couple inches higher. I recently found a need for a front bull bar and moved to a Ranchhand from bumper. It too has a nice high mounted receiver.
Keep up the great work on your rig. I don't always post, but I am watching.
Be well and happy holidays my friend :)
AA1PR
Disabled Explorer
I'm sure with something like the carriage bolts that came with the curt receiver you could do both, but I'd be worried about stress on the frame if it was ever maxed out
AA1PR
Disabled Explorer
HenryJ, many thanks
glad to see you still around
yes I got the idea to flip it from Adam aka bushcoat he stated they did it on his dads rig, to give proper credit
I've seen that bumper & not bad, I'll check out your build & see if its there
& happy holidays to you & yours !
AA1PR
Disabled Explorer
got my son yesterday to reinstall the tow hooks
added a pair of rugged ridge light brackets to get the LED's up higher & hopefully a bit safer, these arent perfect but they're working for now
& I had to turn everything on & We have lots of light out front
AA1PR
Disabled Explorer
here's my latest improvements in the last month, forgot what I had posted lately, so a recap
added a curt 31302 front receiver, with factory tow hooks still there in case & moved the LED's that are wired into the factory fogs up with rugged ridge brackets
replaced the broken 4.5 round LED's with these (wired into reverse lights)
replaced the low beams with NAPA whitelites ( the look of HID)
OK the MOOG # 81069's or for those that prefer the Z71 springs have arrived
AA1PR
Disabled Explorer
ordered these from McBay performance in 1.5", so these will be added with the coil install
& my daughter gave me this for xmas, ts a haul master winch tray; now I need a winch
