UJOR Build Thread
ujoint
Supporting Sponsor
Chris, please educate us what the Pro Rock gets us.
The biggest advantage of the Pro Rock is ground clearance (not really THAT important) and the all new aspect of the build. Its also got a bunch of cool axle geek advantages that are probably in the link below. If you want the best of the best, this is it.
http://www.dynatrac.com/axle-assemblies/prorock-60-axle.html
Did Dynatrac build that with the RCV's already in it? That is sweet if they are doing that. I did not see it on their webpage, but I am on my phone so not the easiest to read.
EDIT: did you not feel the need to upgrade from ball joint knuckles with all the weight on the front of these things?
Yea, the assembled it with the RCVs. We've never had an issue with ball joints, this one has their super duper units anyway. Had to keep this axle RSC ready which is easier to do with the parts we already have spec'd with them.
ujoint
Supporting Sponsor
5 states and 2 provinces in Canada for ol Santa to drop off.
ujoint
Supporting Sponsor
We revised the upper trac bar mount as well as the lowers for more shock clearance.
The lowers have been like this for a while, 1st batch of the uppers.
Gravity
So theoretically a little more up travel then with the new trackbar mounts - is it a noticeable amount? If so, would it be retrofittable with the 6" trackbar I already have installed?
I definitely slammed mine a few times down in Baja last month... once this snow stops I should have some time to install the bump stop spacers you fired out - skiings been too good the last week or 2 - Thanks Again Chris
-d
ujoint
Supporting Sponsor
-d
Yours should already be the lowered mount but not with the curve. Shoot me a pic and we'll ID them.
Chris, will the lower shock mount work on my van? How much more travel do you get?
Lets see what yours look like too.
ujoint
Supporting Sponsor
Yesterday was our spoil the crew day. Started out with breakfast then the boys hopped in V7 and went to Charlotte for some go kart racing. Lunch after that and then back home for dinner with the entire crew plus wives! Good times and I'm thankful for our entire UJ team.
Neil took the carting title from me this year, now we can talk a bunch of ********** until 2016.
mk216v
Der Chef der Fahrzeuge
Yes! Thank you for the continual improvements if/when needed. I can't wait for mine/Fox 2.0's! (free plug; my old and Bilstein's will be up for grabs)
iStan814
