Off-GRID ENGINEERING Dual Battery Systems (An Introduction)
himom
Subscribed. Looking to do a dual battery set up in both my 4th gen and GX. And if I can give a local guy my business it's a plus
BentBomber
www.bomberproducts.com
Do you do all your own machining? I'm in need of some assistance and would be interested to see if you might be able to assist me. Let me know if that might be an option and I'll pm you some more details.
Darkrider
If you were offering a universal wiring kit i would def be interested for a couple future projects that i will be working on.
I do the initial designing and prototyping with steel using all my own tools. Then, I put the design in CAD and have them cut by water-jet. Then I do all the bending and tapping.
I definitely make universal wiring kits! Just tell me how far apart the batteries are and I can hook you up. Or, I can just provide plenty of cable and make you a DIY kit.
All my wiring kits and custom harnesses now come fully labeled for super easy installation
patoz
That is some very professional looking stuff, and I'm sure it performs as such also!
BTW, what is the correct name for the braided sheathing on the cable, and where is the best place to buy it?
Thank you very much! Ive put a lot of attention to detail in these kits. As it should be with any wiring project.
And I can't tell you all my secrets!!
Just kidding... It's called "TechFlex". Or generically it's called PET expandable braided cable wrap. Amazon or Grainger are good places to buy small quantities for one project. Otherwise, there are some bulk distributors online that I could point you to. I buy it in 500 foot spools, lol.
patoz
Thanks for the info, and no I don't need 500', just enough to use on the wiring going to the Blue Sea Systems Electrical Panel I'm installing in my ambulance/camper. I'll probably just get some on Amazon, now that I know what to look for.
mike2100
What do you think about making a bracket/mount for ARB air compressors in that same location under the hood on the passenger side?
4xCoffee
