FOUND Vans For Sale!
eporter
Never seen a crew rig like this. Looks like all the roof panels open up?
https://bend.craigslist.org/cto/5704405249.html
5.9 Cummins Camper Truck:
Truck came factory with the 5.9l Cummins 12-valve with the circular injection (the system you can huge power out of). This truck was purchased new by the California BLM, then to the North Lake Tahoe Fire District... the only 2 users of this truck. I have all the paperwork on it from the factory build sheet to the entire maintenance record.
It was built out as a fireman and gear hauler. Huge storage capacity in the exterior body compartments. Pictures show current state of the truck. Licensed in Oregon with ordinary truck registration, not as an oversized heavy truck, and does not require special drivers license.
~ Truck drives up and down the road perfectly.
~ Surprisingly easy to drive
~ Tires in great shape
~ Brand new bedliner floor and paint in back
~ Meticulously maintained by Fire Department and BLM.
In addition to the 5.9l 12v Cummins...
Spicer clutch
Eaton 5 spd. with 2 speed rear end
Rockwell rear axle
Traditional receiver hitch out back
and too much else to list...
Inside dimensions are 5' wide x 6' 4"tall x 12' long.
The back door is just under 30" wide.
snowaddict91
Spicer clutch
Rockwell rear axle
I dig this thing. Would make a sweet rig for my full-timing plans. I'm really uneasy about giving up 4wd though.
pugslyyy
Time capsule. Someone buy this!
Not mine, etc....
http://inlandempire.craigslist.org/cto/5728870671.html
Wow, pretty amazing shape.
No affiliation, just passing along info. Blank slate with Sportsmobile pop top.
2000 Ford E150 Sportsmobile Pop Up Camper Van CLEAN! - $10750 (Leander)
124,400 MILES
ONE OWNER TEXAS VEHICLE UNTIL WE PURCHASED IT 2/3 MONTHS AGO
4.6L V-8 ENGINE
Can someone explain how this pop up top works? Like, does it have a floor and provides a second sleep area that is accessed by a ladder, or does it just make the roof of the van taller?
Also, what are some good things to search on Craigslist? I'd be looking for a van I can DIY into a camper, or one that is already done. Right now I've been searching for an Astro/Safari but would obviously like to expand my search. AWD/4x4 is nice but not a must, since I'm mostly traveling flatlands.
Texas Aggie
I believe it can do both. I think the top can be raised with the bed attached to the pop top to provide extra headroom, or the bed can be left at the original roof height and the pop top raised to provide a sleeping area.
