Similar to B. I'm building a 5x8 trailer with 24" sides.  i'd basically just use your pieces instead of just cutting an angle iron frame for my top.  My trailer is going to be modular. so it can be a trailer to tote the golf cart around, or a camper for me to go to an ORV that doesn't have cabins.  i'm over tent camping
Mine gets used in many ways too.  The TrailTop tilt-up cover is very easy to remove, even though it's large enough to be awkward for one person to handle - I just hang it from the garage rails.  This photo was taken just after I removed it, then I raise it up on the chains so it hangs high enough to park the Jeep under it in that bay.
When I get around to doing the hard sides for it, they'll be modular and will remove and knock down flat for storage.  I did my military trailer the same way, this first photo shows the complete trailer with the hard sides installed and the fiberglass lid on top (a military trailer it too small to sleep in so I put a roof-top tent on it):
This photo was taken as I was painting the hard sides and before I installed the hatches, but they come apart and store flat as in this photo, then the lid goes down directly onto the tub.
The yellow trailer will work the same way.  Because the corners of the tub are curved, I'll use TrailTop curved corner rails for the vertical corners to match the curves of the tub.  The current TrailTop tilt-up lid will mount on top of the hard sides as in the concept drawing in my previous post.
Doing it in a modular way with TrailTop parts I'll have a completely configurable trailer - tub only with snap-on tonneau cover, tub with tilt-up hard cover, tub with hard sides and tilt-up hard cover.
BTW the TrailTop cover comes in very handy as a "flatbed", in this photo I'm transporting roof molds for my fiberglass LJ and JK hardtops.  I just throw some mover's blankets on the lid and strap the load down.
			I had considered doing an additional 24" hard wall when in camper mode with a 18-20" pop , but not sure about storage of those since most of the time they'd not be in use.  SO, I Say all of this to say, i'll probly end up with a taller pop up and skip the additional hard wall.
Have you found a source for your linear actuators yet and done the design for how it'll all work?
