The Wanderers build
superbuickguy
floor cover
close, trying to decide whether to fabricate or just get another cover
superbuickguy
interior...
white and ugly
now grey
and it all matches... bonus
then wire the gauges
it's in... and not yet wired.... but getting there
opinion time... update the front grill to the 90/91 style? I have an opportunity to get those parts for a very reasonable cost.... not 100% fan of the style, but then again, money is money
superbuickguy
the is the most important picture of today - clutch works great. had to pry on the throwout while my friend cracked the lines at the master.... not pretty but it works
then I couldn't shut the truck off when I got it into the shop... had to pull the plug and disconnect the battery
when I got this, the ignition switch was temperamental - thought it was the switch (and, for those playing along, I commented then that the switch looked new)... it was the barrel, not it works like new
then onto the billions of things left to do... focus now is the electronics so I have gauges and start the floorboard fixes
and then I show you a picture of a speaker
seemed like it was a good idea to replace them since I had to remove one to run the wires for the pillar gauges
this is not helpful, he thinks he is, but he is most certainly not
time to start thinking what this is going to need to be/do when its done. sealed for sure but do I just make the top removable? do I rely solely on the rubber boot to keep crap out? (no)
but in that vein, I should consider what the center console will look like - stock? I'd rather be able to walk into the driver/passenger side but I'm not giving up storage....
superbuickguy
She looks great man! So what are the next things left to get it on the road?
not much, really. Finish the exhaust, connect gauges, and figure out an intake (there could be a snorkel involved). my goals here is 'drives safely', then the interior, then paint it... once that's done, build a camper for it. But the 'drive it' is pretty close. Probably even have working a/c when it happens.
*forgot* I need to set the max boost.
It will be a year before it's painted and has a camper (especially since there's a tray overland bed for my wife's Colorado that's coming before the paint or camper)
superbuickguy
tonight's update. Wiring.
spastic cat
I hate everyone.
in other news, because I'm not a YouTube sensation, I'm going to have gauges, a working speedo and insurance before it hits the street.... I know, I know, but I've never pretended to be an actor and I'm not going to start now
superbuickguy
time to clean up the gauges
wax on/off
and working (best of all, oil pressure)
and EGTs
still need to decode the sensor on the crank... smarter people then me would have written this stuff down when it was all apart...wire is run but need to figure which of the two wires is sending the signal... probably, actually, doesn't matter - ground one, hook the wire up to the other... tomorrow.
superbuickguy
kitty says "leak".... kitty is right
weird part is I dunno why it's leaking there...
first thought was 'failed seal' but it's not, it's somewhere around where the notch that allows oil back into the t-case.... hopefully I don't have to pull the driveshaft to fix it... heaven knows, I'll try some miracle glue first
also the turbo wasn't providing boost...
otherwise, spent some time rearranging stuff... in my schedule, somewhere, I need to go do a firewood load... which means adding taller sides to my trailer... ah well, I'll rest when I'm dead
V45W_Proto2.5
