SkiFreak
Crazy Person
Again, this is a very open ended question.Who is an expert on composite panels?
How do I attach items to interior walls?
The answer will vary based on the type of composite panel, amount of attachment points, the weight that has to be supported and the direction of the forces.
For the specific item you have given as an example... this would likely not be holding a lot of weight and the forces would primarily be in shear.
Tapping plates behind the panel would be the optimal solution, but this would have required forward thinking in the planning stage. Adding these afterwards is possible, but only if you have decent fibreglassing skills.
As others have mentioned already, gluing a plate to the wall and then attaching to that is a very viable option, especially if the load is higher, as the stresses would be distributed over a greater surface area.
That said, if I were installing the item specified, and hadn't planned ahead, I would simply use 4 plus nuts (Google it), as they would easily do the job and their installation is very simple.
Edit:
I failed to mention that another very viable option would be to use VHB tape.
