UJOR Build Thread
ujoint
Supporting Sponsor
Engine is finally running like a top, so the rear bumper is on and next is the skid system..... More pics tomorrow. ---- Van leaves Thursday!
ujoint
Supporting Sponsor
Nice progress today, finally installed the rear skid. I've still got a healthy list of things to do, and hope to wrap it up tomorrow.
Here's the blank skid after powder coat
And with all the goodies bolted down
Installed....
shawn_nj
Wow that is such a sano install. Very clean. If that tank is 20gal, looks like you could easily get a 30gal installed in the same spot.
scotter
Awesome set up Chris, very wel thought out. I may have to borrow your concept foe implimentation on my van. :Wow1:
ujoint
Supporting Sponsor
Thanks fellas!!!!! There isn't an interior access, just the quick disconnects & air chuck in the rear bumper. I'll have some detailed pics tomorrow. If anything needs to be serviced, it takes a floor jack and 5 minutes to lower the whole unit.
Thanks. There's a body rib directly in front of where I have the tank mounted, so a larger tank could be used but it would need to be shorter to clear the body. Or.... Make the skid hang down lower, this setup has a 3" drop.
Life_in_4Lo
I'm so impressed with your builds!
Previous to seeing these, I could care less about the F vans and never thought of them as anything of serious consideration.
You really exploited the potential and made a very cool product. I really want one...
ujoint
Supporting Sponsor
Thanks very much!
TangoBlue
American Adventurist
You are a true craftsman Chris. Need to play the lottery more - can't quite part with my Tacoma....
ujoint
Supporting Sponsor
the customer isnt concerned about freezing possibilities of the water in the water tank?
Not in FL...
Thanks, keep playin & then you can have both!
I got all excited when I saw this until I realized that my '78 happens to have a fuel tank right where this all fit...:mad:
Yep, that causes a little problem...
Lockwoodjd
