2006 4runner Sport w/ pic's of my 1st mod's
Ryanmb21
Well it's been 5 years with my 4runner and about 60,000 miles. It has done everything I've wanted, granted, 99% of the miles have been on-road but I've enjoyed some light duty 4x4 trips to Arizona, Utah and California. Many, many succesful road trips.
Since the beggining I've had an OME lift, 265/70/17 tires, and sliders. At 45,000 miles I switched to 255/75/17 tires and with this combination I've been happy. Knock on wood, no mechanical problems, only routine maintance and my truck seems happy. Highlights have been reliability, comfort and 20mpg on the highway and capable enough for me.
Out of curiousity, I decided to try some new stuff for the next stage. I just ordered some new parts
-Icon extened travel coilovers
-Icon piggyback rear shocks
-Total Chaos UCA's (to allow 1" extra downtravel and bring back caster I lose from lift)
I'm also going to build a storage deck that will include Mac's versatie track bolted down to metal, include a pull out table. This should give me a good base to attach a sleeping platform and safely tie down some large pelican cases that I plan to use.
Looking forward to another happy 5 years!
Ryanmb21
Storage Platform
I built a storage platform in the rear cargo area.
Wood template, in this step I wanted to get the rear most horizontal beam over the factory tie down holes the outer vertical beams fall over the forward factory tie down holes (which are elevated ~.5-.75” off the floor.
Using 1x1 steel square tube, the template was welded up and holes drilled. The frame gives 2” rise from the floor, this is important to the design because (1) I needed 2.5 of rise to get level with the folded down seatbacks, and (2) I needed room for my two slide out tables pieces. To the top of the vertical beams I added Mac’s Custom Versatie tie down aluminum track, which was ½” thick and brought the platform to level with the back seats. This stuff is incredible, I chose the kind for flush mount and each tie down has 1,000 lb dynamic load rating. I used 1/8 wall steel tube and drilling the holes was tough. I also drilled out the rear nuts and elected to go with a bolt through the floor with a fender washer. The factory nuts looked weak and feeble, this step took 30 seconds. I reused the sound deadner after pealing it off of the factory carpet, seems to work well so I didn’t pay for dynamat (Note, without any sound deadner it is LOUD, plan to use something).
With ¾ birch plywood I cut pieces to match the contours of the floor and sanded the corners round. I also cut 41” slide out table pieces to fit under the center left and right sections.
Next, I added Line-X. I debated weather to stain the wood and add varnish but I am so glad I chose to use Line-x. It looks fantastic in person and soft/rubbery enough to allow for climbing and kneeling on.
The finished product, with tons of tie down options all solidly anchored to metal and level with the front seats. The tables are nice and much more sturdy that I planned, I would guess each could hold more than 25 lbs.
Here is how it looks with two Pelican – Storm cases 2750
keezer37
The recessed tracks look good. While I like the look of stained wood, the Line-x better suits the overall appearance of the truck.
Two thumbs way up.
cbradley
That looks great! I'm glad to see the final product. I've been contemplating copying you since I saw your mock-up at Demello's.
4RunAmok
This thing is looking awesome!
Nice choice on the Total Chaos uppers, have had mine for a few years now, and have zero complaints.
Ryanmb21
Two thumbs way up.
Awesome idea, very well executed!
Thanks for the kind word guys!! :smiley_drive:
Ryanmb21
Icon and Total Chaos
With some very generous install help from Jon, Jeremy, Shuly, Sid and Jarrod from toyota120.com I'm riding on some new Icon gear! :elkgrin:
Redline
Likes to Drive and Ride
Wow, what a transformation Ryan, good for you!
I love the tie-down platform and agree that the slide out tables are 'the stuff'. I'd like to copy that design too.
Ryanmb21
Thanks! Let me know if you need any info and/or measurements. Perhaps we can just trade trucks straight up ;)
Redline
Snip.... Perhaps we can just trade trucks straight up ;)
Well you do have a nice rig, let me think about that for a few minutes....
Naw, probably not a fair trade, mine might have a few harder (s)miles on it than yours, AND I still like it and want to drive it another 200k.
Soon yours will be better than mine :)
V45W_Proto2.5
