ARB 4Runner Build
Whewww
It would be a good idea and utilize this old Phoenix Gold circuit breaker from an audio installation in my old rig, and run 4 gauge wire from my aux. battery to it, then another 4 gauge (presuming 4 gauge is big enough (it powered two huge Rockford Fosgate amps in the old rig) wire back to the compressor, then just ground the compressor with a short piece of 4 gauge wire in the back.
My generic wire gauge vs amps chart shows 4ga good for a 25 foot run @ 50 amps....
Make sure you ground it to the chassis and not the body as the ground wires between the body and chassis probably aren't sufficient for this application. That, and, most if not all of the "important" electrical things such as engine ECU, lighting etc are grounded through the body and you want to keep the aux loads pretty well isolated from them.... Esp in my 2011 FJ where there is a lot of "can bus" systems running around using only 5ish volts. It doesn't take much to piss them off......
YMMV RON
The new twin compressor comes with a pretty lengthy harness. If you use a power distribution block as we did, you would want a minimum of a 6 gauge wire. We used 4 gauge because the of the fridge, and other outlets plus we may be playing with a solar power system during the overland rally.
Next week is bad. A few of us will be out of the office for the NW Overland Rally and we will have visitors from Australia.
After next week, no problem.
Thanks, then maybe a few weeks out I will stop by after work.
That is great the compressor comes with a harness, maybe if it is long enough, I can run it from the rear there up to the aux. battery.
If not, I have power distribution blocks left over from the old rig too.
YMMV RON
Thanks Ron for the tip on going directly to chassis instead of somewhere in the rig.
You can see in the pic above I used the small distribution block as a ground only for my two RF amps in the old rig, and grounding to the sheet metal under the seats was sufficient for that rig, but best to follow your method in the FJ.
The ARB 4Runner is looking great.
I am sure I will see you guy's tooling around town in the mornings in it sometime, I often see the badged rigs when I am going from KB Boeing back to the Longacres site I am based out of which is near you.
Are you guy's going to do a wrap on this rig like the silver FJ Cruiser you use to have, and I believe a red H3 was badged too?
I use to see the H3 on my between job sites, but have not seen it in quite awhile.
Never have seen the Jeep that is wrapped in OME until I stopped by last week to get the catalogs.
And time for the list. All prices shown are MSRP. Note: This is not an application guide
3421520 ARB Winch Bar $1237.77
Warn VR10000 Winch $579.99
6821201 ARB fog lamp kit for bar $91.74
900XSD IPF Driving Lights $306.24
2887 Front OME Coil Springs $176.19
90010 Front OME Nitrocharger Sport Struts $174.13 each
2898 Rear OME Coil Springs $176.19
60081 Rear Nitrocharger Sport Shocks $109.66 each
RD111 Front ARB Air Locker $1095.64
RD193 Rear ARB Air Locker $1095.64
CKMTA12 ARB Twin Air Compressor $544.50
171302 ARB Tire Inflation Kit $36.66
171503 ARB Air Locker Manifold Kit $66.75
3813200 ARB 70"x49" Touring Roof Rack $659.52
3722010 ARB Roof Rack fitting kit $202.85
ARB3101US ARB Roof Top Tent $1568.51
RF945US ARB Roller Drawer/Floor $617.22
RDRF945US ARB Roller Drawer/Floor $828.06
10800782 ARB 82QT Fridge/Freezer $1232.23
10900010 ARB Fridge Freezer Tie Down Kit $28.11
10900011 ARB Fridge Freezer Wire Harness Kit $46.94
217361 ARB Black Valve Stem Caps $9.96
We have other stuff as well, but the list above shows all the hard mount parts.
We will probably do some sort of wrap eventually. The H3 was wrapped as well, and has been sold.
The OME JK hasn't really been around much. It was on tour with the 4WPW truck fest this year. It should be back home any day now.
Well it's pretty much done :wings:
Sinister indeed
Love it; but sinister? something looks off, maybe just to me. Wheels? Maybe wheel and/or tire size vs lift?? Maybe it is just too clean...
Thanks for the thread. I will be contacting you guys. Great stuff all 'round.
Just have a few things here and there. Wish we got the black wheels in time for the Overland Rally, but the truck still looks really good!
Hmmmmmm? Being disabled w/ a parking permit, I can't help but notice that this vehicle isn't sporting one mate! :coffeedrink:Hmmmm....
It will be sinister with the black wheels. Plus it doesnt look that great from that angle.
Can you show us any more about the roof top tent quick release system?
Thanks,
Don
The quick release system was just something we threw together from pieces from our local hardware store. We want to do some testing before sharing anymore more information.
2eleven
