Did you do any upgrades/changes to the transmission while you had it torn apart? I'm contemplating a stroker when my 220k 4.0 starts to lose power.
Thanks,
Troy
Very cool.
Can you refresh my memory? What compression ratio is the engine?
Out of the box with 260 HP @ 5200 rpm, 295 ft lb torque @ 3400, 9.2:1 compression ratio. These numbers are based upon factory intake & exhaust and 24 lb injectors. That being said, a Hesco 62 mm throttle body, Thorley header and 26 lb injectors are being used as a part of this upgrade so I think the numbers will be closer to 280/HP & 315 ft lbs.
Factory specs were 190 HP @ 4750 rpm, 225 ft lbs @ 3950 rpm.
9.2, eh? And you were pinging on 91 octane? Is that normal? Seems like you should be able to run lower octane with out pinging (but I'm far from expert on such things).
