M100 Hub Swap/ Axle Help Please
kadenm
So I want to add some different wheels/ tires (15in with 235/75/15) onto my M100. I know most wheels won't fit because of the center hub cap diameter. Would it be as simple as swapping the hubs to these https://www.etrailer.com/Trailer-Hu...xle/84557UC3.html#exp-productdetails=.reviews ... then adding a new set of wheels?
I've been searching all over, and can't find an answer to how people swapped hubs or which hub they purchased that fits..I took the wheel off, but how do I even get the hub off? Do I have to unscrew the center piece in the attached picture?
OR if I it's not as simple as swapping hubs I will switch the axle, what size axle are people running on the m100?
And it looks like the axle is only held on by the u-bolts, so to swap axles would I just unbolt the ubolts, remove axle and install new one?
Yes just order the same diameter axle and length and new I bolts
Sent from my moto z4 using Tapatalk
Bobbyjr
