My new vehicle: 2005 Nissan Frontier
Moving down the road: a mid-project evaluation
Water Tank and Shower
I’m going to search for a slightly larger tank of 16-18 gallons. As it turns out, we tend to use this water source for cooking, washing dishes, and showering only (drinking water is stored in a 20-liter Scepter water can). A single econo-shower can use 4-6 gallons, and since the Sureflo pump can crank out 2.8 gallons a minute it can deplete the source fast at full speed. Washing-n-cleaning water is easy enough to replenish if we hit civilization, but a little larger tank will be a good thing to get.
The shower is one of these:
Currently mounted inside the tool box on a custom deck, it takes up too much space. The attached hose is 6’ long and often difficult to pull out and/or stow. While the shower head has two settings – a spray and a stream – it is not trigger-actuated. A sprayer with a trigger would work much better. So here’s my idea for improvement: make a 6’ long hose with a trigger sprayer and a quick connect that “plugs” into a female port mounted on the truck somewhere clever. This would be the hardware:
The reason for this is to save space, and make it easier to use the water supply. We’ll store the hose and plug it in when we want to use it. I think I need to put a valve in the line as well; turn on the water, open the valve, and hit the trigger to release the water. Another dude has done something similar:
I don’t have a photo of the tool box showing how the water pump and shower is situated in there. Bummer. But I’m going to move the pump out of there, too, thereby freeing up a bunch of box space where I’ll probably put tow straps, gloves, and other utility or recovery items.
Bed cap / platform / deck
This is going to be exciting. I’m building a bed cap with a steel (tube) frame where I’ll be mounting a pair of Yakima load bars with their custom mountable Control Towers. This photo shows my concept, but not my execution:
The tent will attach to the load bars. ROCK ON. Also, the load bars will be long enough to allow me to tote two bikes, one on each side.
I believe I’ll be able to incorporate my water chuck on this cap, perhaps in a protected box with the valve and a switch for the water pump . . .
Drawer Storage System
I’m in the concept stage. On our last trip into Baja, it occurred to me how I could do a drawer system in the bed. Currently, we have this large Rubbermaid bin where we keep all the camping supplies other than the bedding (which remains in the tent). The bin is about 15” tall, 30” long, and about 22” wide – I’m estimating here. I thought, “Hell! Why not build a weather proof drawer box that’s about the same size, but longer to take up the space from the tailgate all the way back to the tool box?” We’d store the camping essentials in there: headlamps, extra batteries, the stove, flatware, plates, paper towels, pots, etc etc etc. Plus, I’d be “creating” a little more space (save the Laws of Thermodynamics).
Fridge
I know I’m going to end up getting one of these. I almost don’t want to, but Brooke thinks it’ll be the coolest thing (so to speak). Here’s my issue: It can’t be any taller than 18”. It absolutely must go in the truck bed instead of inside the cab, and I’m limited to an 18” working height with the bed cap in place. I like a good challenge.
The Rear End
I've installed a gas spring to the swing gate, which is frickin' sweet. Remember when I told you all about the nasty dents the swing out caused because the gate stop was welded in the wrong place? (Here's a photo, the story is at the bottom of this page). Well, this gas spring props the gate open now and doesn't allow the gate to swing freely. It also makes the gate "feel" good when opening and closing it since it has a little pressure pushing it open.
And I figured out the hi-lift jack mount - in my original attempt to mount a jack, it appeared I needed to remove the jacking mechanism from the ladder. Not so! But I did have to hammer one of the mounting points to get the bolt to line up with the holes in the jack ladder. Sierra Expeditions provided the new 48" Hi-Lift X-TREME.
And I picked up a fuel can holder from the gentlemen at Adventure Trailers, which I think I'll have welded in place of the current fuel can holder:
It'll look sweet.
There you have it. You do a few trips and you go, "Hey! This doesn't work like I planned." So you have to re-engineer a few things from time to time. But it sure is fun.
:beer:
Cool stuff Mark. Let me help you with the refrigerator -- baby food has to be kept cold once opened, same with bottles. If you intend to travel with F'n Jr., a refrigerator will make your life vastly easier. Plan for it now.
Excellent point Bill. Also, on my recent 2 week Baja trip, my travel companions had a large cooler and there was some serious Fridge envy going on. I loved it on my trip, potentially best mod so far.
its for the safey of your family!
articulate said:
....You do a few trips and you go, "Hey! This doesn't work like I planned." So you have to re-engineer a few things from time to time. But it sure is fun.:beer:
It's fun to watch you do it. Shoot, it's fun to read about you doing it. When things don't work out for me as I planned, it's usually just a big PITA. :mixed-smiley-030:
18" clearance for the fridge should still allow for a 45qt right?
Why does the fridge have to go in the truck bed?
You've got four doors...put one back there. You're only having one kid? Right? After all. Ask everyone how nice it is to be able to reach back and grab a nice frosty beverage from inside the cab, versus going outside.
FYI...The Engel 35 is only 16" tall.
Gracias! Out of a clinging desperation in my final 90 days as a non-dad, I'm going to be spending money on crap I shouldn't. The fridge sort of fits that, except Brooke really wants one. It's coming.
flyingwil said:
What about a drawer unit Waeco Fridge?
Okay, now I know what you're talking about. I'm actually thinking about the Waeco 35 (IIRC). I need to make some measurements.
All good points. Maybe I'm a freak. I want it in back because we already fill up the cab with other stuff, and now that we're inserting a little bundle of joy in a car seat . . . I suppose I could make it work. The responsible part of me (which is small, weak, and never wears t-shirts) thinks that a fridge isn't a terribly safe thing to have next to my offspring - maybe it's safer, actually, since it'd be bolted down. Well, unless it's held down by bungee cords, which I recently learned are not permanent.
I like the idea of saying, "Hey kid! Pass your daddy a Taco Chaser!" while bombing down a corrugated track in Baja.
Otherwise, it's better off in the bed so we can keep sippy cups, camera bags, dry snack food, and space for a hitchiking Federale. This does pose an interesting problem of making a well-sealed case for it. I can't imagine the dust is a particularly good thing for a fridge to be breathing. I like a good challenge.
Barkeep! Another mekong please.
We'll see . . . :Astrologist:
One for me and whatshisname, my new best friend. Man you are too funny. I think your logic about putting the refrigerator in the back is solid, but I think you are going to want it in the cab if you can. Check out the weights, might be less than you think and from what I understand they are pretty solidly attached. Also, sippee cups and the fridge side by side will be nice.
just get two fridges, the big one (under 18-inches tall) for the bed, then a little 16 quart for behind the seat - best of both worlds and hey, it's your money, not mine, so it's even a better idea.:yikes:
You first. :) Kind of a clever idea, actually, but entirely cost prohibitive. With two fridges you could keep a bunch of popsicles and ice cream frozen while keeping fruits and veggies chilled. Not bad.
Speaking of my new best friend . . . I can't believe someone actually caught that quote! Way to go. I owe you a popsicle from my auxiliary fridge. Yes, of course you can keep the change.
:iagree:
Great looking bumper!! I love your writeup!!! From the pictures...looks like their welds are VERY clean from the photos!
Can't wait to see it in June!
A job well done!!!!!
:clapsmile
5mouse
