Overland Journal Project Land Rover Discovery 4 (LR4)
We have a new app coming out, btw, designed for the iPad (and later Android tablets or PC / Mac via USB). We will make an official announcement in the coming days. There are some great new features coming...
woohoo...can't wait to hear what the new features are!
I really like the General Grabber AT2 as well. However I'm playing with the idea of going to 275/65, it opens up the choices.
I am not sure what modifications I would need to do or if I could simply get some rods (probably Sasquatch).
Update:
- Original config: 2011 LR4 with 20" P-rated tires (worked for previous owner in New Mexico)
- 30mm spacers
- 10 spoke LR3 wheels
- General Grabber AT2 LT285/60R18's which are 31.5" OD and 11.5" section width
- Stock height to fit in my FHA approved garage (no rods)
Issues to fit the above:
The 30mm spacers are minimum. One caliper did rub slightly on the ID of the LR3 wheel. Left a mark and you could hear it. Needed to kiss the caliper on the ribs. Manufacturing variances can result in some interference.
The 31.5" OD tires DOES NOT fit in the underside location without modifications. Removed heat shield, cut ends of suspension bracket/shield mount, sectioned shield into 2 pieces and remounted.
A 285/60-18 tire does require some trimming of plastic on front wheel leading edge. Will also require some trimming of frame extension / body support. (still in the works)
Load range E tires work fine. Currently inflated to 40psi but will need to experiment. At least I can now move up when loaded.
Truck now stops on snow / ice without traction control kicking in, on a dime. Probably should be worried about people behind me. :-)
Pics later.
Is it the 31.5" diameter or the 11.5" width that causes the rubbing issues? If you had a 265/65-18 tire that is .75" or 1" narrower do you think you'd be having the same issues?
For the wheel well thinking that 265/65 at 10.7" would help but maybe not. The 285/60 is 31.5". Keep in mind I'm stock height.
I would expect the same issues for either size for the stock spare tire location.
I have a 2010 LR4 with 18" LR3 wheels + 1.25" Bora spacers and 265/65-18 BFG AT rubber. I've added 36mm of lift using the IIDTool. There are minor rubbing issues behind the front bumper and frame horn only when the steering is cranked nearly all the way. The outside edge of the tires just graze the plastic inside the wheel well. It is noticeable when backing up as the lugs grab on the edges of the plastic and the tops of the screws holding the panels together. I'll have to post some pictures to illustrate. No rubbing at all in the back, even when under full compression.
As an alternative to using the spacers I'm wondering if the inside of the LR3 wheels could be machined away to clear the calipers or perhaps there's too much material to remove to be safe?
Update:
- 30mm spacers
Pics later.
Thank you for the update.
I really like the General Grabber AT2 but I might go with the BFG TA KO in 265/65R18 after reading this (still like the Toyo as well).
I have the same LR3 wheels (10 spokes) which I'm planning on painting (or powder coating...$$$).
Just ordered the BORA 1.25" spacers, they come out at 32mm and I really hope it's enough (otherwise I'll have to grind the caliper a little which I'm not really enthusiastic about). They should be ready in a few days.
I'm hoping to be all set within the next 10 days or 2 weeks.
Post some pictures when you can, I will do so as well, as soon as everything is together.
Axel
PS: are you in New Mexico? I'll be moving to ABQ for a year at the end of June '14
The BFG LT265/65R18 is 31.7" OD vs. the GG AT2 at 31.5". But, section width is now 10.7" so you might experience less interference with the plastic trim pieces. I would expect the BFG to have the same issues for the spare, maybe slightly more?
Forgot to add - Instead of dismounting my original 20" tires and pulling the TPMS, I bought some ITM's. They worked fine. If I head out across the flatlands I will probably swap back over to the 20"/P-rated combo and save the AT2's.
I'm in Colorado Springs. ABQ is "in the area". I would think you will tour Colorado during your time in the Southwest. Let us all know when.
Still waiting in the spacers. They should be here around the 24th (hopefully sooner as the snow started and the Conti 4x4 are indeed crap in the snow until it's get a couple inches deep).
As I'm waiting for the spacers I'm still looking at tire options and still wondering why not go 32.1".
In any case, I'm now also considering the Cooper AT3 and the Hankook Dynapro RF10 ATm (265/65R18). Both supposed to be as good or better than BFG TA KO and better on road and on ice and snow (especially Hankook).
I'll definitely let you know when I head your way.
I'm running 265/70/18 Cooper ATP's with spacers, and lift on my LR3. I had to trim the front bumper cover back about 1/2 an inch, and the fronts barely rub on the rear at full lock. The rear tires only rub slightly at the pinch seem.
Jim
Excellent road-biased tire. I have 20k+ km's on a set of these on my L322 RR. Quiet, good in dry and wet, excellent wear characteristics. I don't have much snow experience with them, tho (didn't snow here last winter).
I have the dynapro's as well. I love them for the highway, awesome wet traction. They are my current limiting factor on muddy trails. However, I have no desire to play in soupy mud all the time. They have really impressed me with what they have made it through though. Honestly I think it is due to the LR3 rather than the tires, as far as making it through the slop that I have so far.
This is really good to hear as I think they're the ones I will pick.
Now I just need to settle on size. 265/65 or 275/65.
That being said. After my wife pickes her new vehicle (hopefully an LR4) I intend change to 275/65's in - likely duratracs - for something just a little more aggresive. This is because my LR3 won't be our main family vehicle, so I can afford the minor trade off potential in road comfort etc. I only have a 4 mile commute :)
Thinking the jump to 275 and 32"+ OD will require Johnson Rods and a new rear bumper that includes tire carrier. (Kaymar?)
So budget accordingly and start with the rear bumper, end with 275 tires.
Plastic modifications/relocations still required.
Bobbyjr
