Willman's Bantam BT3-C Expedition Trailer Buildup
Willman
That is a really clean looking trailer. Nice can holders on the tongue.
I wonder on the fenders if you could cut them in half, spread them apart and weld in a small flat section at the top. That way you could accommodate the larger tires as well as keeping some of the original shape??
Willman said:
This photo would crystalize what type of fender treatment to apply to my trailer if the tow-rig and trailer were mine!
You have a beautiful setup in the works, Nic! GREAT work so far!
Martyn said:
Willman
Great idea!
But.....I was thinking of conning 2 fenders off you guys......:chowtime:
Thanks guys!!!
A set of AT fenders would sure hit the spot Martyn!!!!!:shakin:
If they don't want to part with two....then it back to the drawing board....
Might just have to fab up some of my own.....
:REOutArchery02:
Trailer
The trailer is coming along very nicely!
With your skills, I'd make a set. Not very hard to do. We made up a set for my friend's trailer using cardboard to lay it out then cut up some 1/8" steel plate, bent it using a home made metal bender in a shop press then welded it up. Came out lookin great. I'll see if I can find some pictures.
Cheers,
P
Martyn said:
Willman
This is what I'd do!
That, or cut off the inner & outer lips and weld or rivet them to a wider rolled band. My grandfather did it this way (riveted) on the utility trailer I'm about to inherit.
That trailer is looking a lot different than last summer. The truck is too -
Nice work as always Nic - :clapsmile
Lid
Thanks guys!
Lid Construction!
Still need to weld down the sheet metal
Here's my layout for the lid
Lots to do!
:jumping:
It's a Blacksmith/fab table. It has tons of jigs that goes with the table too (clamps, pegs, and etc..). It makes life much easy in the fab world when you have to do piece after piece.
Those are really nice tables to work off of. Very expensive too. Whom ever scarred it with the grinder needs to have his hands slapped. :)
Lid parts coming!
Lid parts list:
(McMaster.com)
- Steel Piano Hinge for Tight Clearance W/O Holes, .090" Thick, 2" OpenWidth, 6' Length, 1/4" pin #11785A33 x1
- Gas Spring with Threaded Ends 150 Force, 26.38" Extended Length, 10.24" Stroke #9416K212 x2
- 10 mm Ball Socket, M8 Thread, Steel for Gas Spring with Threaded Ends
Please enter a quantity. #9416K79 x4
- Ball Mounting Hardware Steel, Flat Ball Bracket
Please enter a quantity. #9512K91 x4
:wings:
How time to think how to keep this lid down and locked......thinking a hasp with a lock will do the trick.......What do you guys think?
I have the slam lock set up
It does work well and is a very clean set up but..
If I were to so it over again (which I might) I would copy AT's lock/clamp design.
(apologies to Mario and Martyn) :bowdown:
The reason is it is more of a compression lock and you can really clamp it down onto the weather stripping for a tight seal. And the mechanism is all on the outside, no need to worry about something getting stuck or out of adjustment (where you can't get the lid open) Ask me how I know when we are around the campfire...:smileeek:
I am planning on one of these on each end of the lid to keep it closed.
LukeSkywalker515
