Afford9217
The previous owner goes by drlee on this forum. I wanted a look at this with a view to buying but by the time I decided I was serious it was already sold.
			His name is Dean and he just lost his wife to cancer.
His goal is to take the Fuso down to Baja full time and surf a lot as he puts his life back together.
Camped next to us last weekend at Inskip Point.
The big pantec used to carry a Jimny in the back but he upgraded to a 75series which he tows on an Aframe......I think he told me that he's been on the road for 7 years in his truck....... not bad for something that started as n old removal truck for only $3K. Lots of custom hydraulics...even has a hydraulic Saturn TV antenna.
The NPS on the right was an old Ergon Energy truck so came with the really good hydraulic APE rear winch setup....then the owner ran some pulleys under and setup a fairlead on the front bar....pretty cool . The slide-on comes off for the extreme fishing trips with the boys and camping gear gets thrown on the tray.
I think it's probably one of the winches expo member, Mickldo would have originally set up cause they built all those trucks where he works.....they even run a cooler and if you've ever seen them, you'll notice they had a capstan on either side of the winch.....Ergon would use the capstans for pulling power cables. Sometimes they would winch for hours on end , hence the cooler I guess. They even setup the new trucks that have DPD'S with a lockout so that the regeneration doesn't activate while the PTO is engaged. IIRC these trucks ran the 10,000lb unit .
BTW APE winches are all wormdrive and they rate their winches as a lift so not sure how that compares to conventional ratings. What is the conversion anyway?
Gee we were all waiting and thats it!
