Sure-Fire Ways to Improve Your Roof Top Tent
parapyropig
Gorilla Wrangler
Majorly kewl!!!!
So stealing that idea, too. :)
I might not over-engineer those, speaking for myself; I think I'd want a built-in failure point to avoid damage from unintentional overloading.
Rattler
Thornton Melon's Kid
Do these work with Eezi Awn tents?
If they have the same size channel as the Mombasa and CVTs (the ones I know they work with so far) they will. I should have a little more info in the next couple of weeks hopefully.
cactusjk
Thanks! I have considered starting a thread on Eezi Awn accessories to see what is out there.
compactcamping
Still looking for anyone who has done this mod to an Eezi Awn.
Haven't don't it myself yet, but easy. Just rivet or screw a set of footman loops to the based at the four yellow highlighted locations.
Then the straps for a Shoe Hammock or ???, attach to the foortman loops instead of a track slide
cactusjk
Looks like the best way to go. I am thinking it is best to screw into the plywood base if there is enough material there to securely hold.
cactusjk
From the article:
n addition to its use as a table, I have developed a way to attach the AJIK mat against the front edge of my Eezi-Awn roof top tent using some string for support and two 3/8″ steel rods secured by four similarly-sized pipe straps as braces. It basically creates a “balcony” for dirty shoes and sandals just to the left side of our ladder. (I can’t tell you how nice it is to not bring them into the tent anymore.)
Would like to see how this mat actually attaches to the front of the tent.
Just get some T nuts or threaded inserts and stainless hardware.
off_to
