sub-terminal
Do the swivel seats lock in more positions than just forward and backwards?
Thanks!
Thanks!
Thanks!
It could if you wanted to cut another slot for the lock arm to engage with. You get the best reclining action with the seat facing rearward. Anything in between and you're limited in how far you can lean back because of the door.
A couple things to consider about those seats.
-Only the middle seat has an integrated seat belt. You'd have to come up with seat belts for the other two seats. Not impossible but also not trivial.
-The mounting flanges are different than either the recliner style seat or the 2nd row captains buckets. You'd have to come up with a new way to mount them, there isn't an "off the shelf" solution like there is for the other seats.
I think a guy could make them work if he really wanted to but I see it being quite a bit of effort (assuming they fit in the spot you want them. I don't think they'd fit between the wheel wells in an E-series).
So for your front seat mounts, you can use the reclining seats for both driver, and passenger? And just use the sienna seat belts?
Thanks
Morgan
Yes, the recliner style seats fit in the driver/passenger locations.
Do any years/models have non recliners to use in the front? Or are the fronts from the sienna non reclining and use your mounts also. Seems like all I see is recliners or that pair with the jump seat in the middle.
Did you end adding additional holes in the newer brackets for the non reclining?
There are two issues with the Toyota belts in this application.
1) The integrated belts get tighter as you drive and won't allow any slack. Not very comfortable for a driver in my opinion
2) The Ford Restraints Control Module needs the pre-tensioners in order to function properly (pictured below...that is the Ford pre-tensioner/seat belt receiver). I adapt those parts to the side of the Sienna seat (simple process actually) and retain the van's original seat belts.
Okay, gotcha. I was wondering what exactly was going on in that post. That makes sense now. What is the lead time on front bases? Say I paid today, how long will the weight be, ballpark?
Thanks
Morgan
This week in particular I have a few projects already going so it would be early next week before I could ship out a set.
