I'm actually a bit shocked that this has not been asked before (if it has I've just missed it) but how does the turning radius of a 6" lift 35" tire Ujoint leaf spring conversion compare to stock? What is the radius difference between the 6", 35" setup and a 4" lift 33" tire conversion?
How does the coil sprung setup compare with stock?
Any actual measurements?
Jeff
Jeff
Another question....is the coil conversion kit only available in a 6" lift? Any way to get it closer to 4"?
Jeff
Run 33's instead of 35's and you're almost to your goal. There are also a few springs you can try that will sit lower but you'll lose bump travel.
	Chris, normally, hard mounting something from frame to body, in this case a ladder from the bumper to the roof rack would be bad but with the stiffness of the body on these e350 vans, is that rule nessesary? Aluminess somewhat does it with their tire mounts by having you mount the unit to the door hinge and frame but that's not nessesarily a "hard mount" either. Thoughts?
I just posted this to FB, will post here too. ---
Alright folks, I may be putting V8 up for sale to fund some other projects, will offer it here 1st and then she's going on eBay. 24k as is, add 4k if you want the 4wd conversion completed (transmission rebuild/4x4 conversion, shortened fuel tank, exhaust mods, t-case and driveshafts) Van has 260k on the clock, engine has 130k and is a 5.4. Was a locally owned fleet vehicle, bare cargo van. 4.56 gears, Stage1 front axle, coil conversion, 6" rear springs, new shackles and hardware, Fox 2.0 shocks and stabilizer, A-Team wrap, Aluminum front bumper, General Grabber X3 tires, Yukon diff covers, Rigid headlights, bushwhacker flares, Rigid reverse light in the bumper, cheapo 80s style lights above the windshield. Runs great, it will scoot! No issue with burnouts! Plenty of pics here on FB, PM me if interested and we're happy to outfit it anyway the new owner likes. Thanks
(no need to comment on the price and whether you like it or not)
brian94ht - You could definitely lower the ride height if you wanted but its going to hurt the amount of up travel in the suspension and make for a harsher ride over jarring bumps. I personally wouldn't do it. That and with Chris's 4" rear springs it sits almost perfectly level.
You don't have any weight in the back, like nothing, gutted. Put campervan weight in the back and it will be saggy. I will post some measurements with my bed panels, drawer slide, fridge, etc. pulled out of BATVAN in my build thread.
Of course I have rear springs out of a 6" lift van so.....
I'm sure that most of us have seen the interior lights come on when twisted up...
SoCal 7.3 is back from paint, ready to tear down! We already have it stripped, tranny goes to be built Monday and we have the frame ready to clean. Should have an axle under it by Tuesday or Wednesday.
