2021 RAM 3500 Tradesman | AEV Prospector | FWC Grandby
ramblinChet
My primary goal in designing my on-board air system was to create a fast and reliable solution for inflating tires to appropriate pressures when transitioning from off-road to on-road. The difference between a 10-15 minute inflation time and the more common 20-30 minutes is significant, especially when trails demand multiple transitions in a single day. To optimize this process, I mounted Milton HIGHFLOWPRO V-style brass couplers on both sides of my vehicle, between the cab and camper, allowing me to connect to the driver’s side, inflate both tires, then repeat on the passenger side. I sourced 3.5x3.5x3.5-inch aluminum brackets and secured them to the base of my aluminum RotopaX carriers.
To centralize the air system accessories, I mounted a Milton Safety Blow Gun with a 10-inch extension on the rear wall of my camper, adjacent to the air system. I used three spring clip holders for mounting, and it remains to be seen whether these clips will securely retain the blow gun on rough trails.
The next phase involved transferring pressurized air from inside the camper to the external brass couplers. I applied masking tape to mark measurements, transferring precise data to ensure accuracy. My objective was to drill a 24mm hole through the aluminum base of the air compressor mount and a horizontal camper surface while avoiding a 3/4-inch-thick blind vertical wall. The hole needed to be close to the wall without contacting it. Through meticulous, repeated measurements, I achieved satisfactory results. A high-temperature silicone rubber grommet was installed in the hole to protect the air line, as shown in the accompanying image.
While inspecting the engine compartment, I noted significant dirt accumulation, prompting a thorough cleaning before my next trip. I installed a Victron Energy MEGA Fuse Holder to power a Victron Energy Orion XS 50-amp DC-DC charger, which charges my house batteries while driving. Based on my calculations, Ancor 4 AWG wire was suitable for this application. The RAM's High Amperage Power Point (HAPP), an M8 stud on the battery rated for 300 amps, facilitates this connection, located on the driver’s side within the power bus.
Recently, I noticed a soft grinding noise from the front of my truck at 15-25 mph, louder during left turns and quieter during right turns. Despite my hearing challenges from past exposure to helicopters and machine guns, and my habit of driving with windows down and radio on, I suspected the passenger-side hub assembly (wheel bearing) was failing. After driving briefly and stopping in a parking lot, I confirmed the passenger-side hub was significantly hotter than the driver’s side. On a 95°F day, the driver’s side was hot (approximately 110°F, touchable for 5-10 seconds), while the passenger side was very hot (approximately 120°F, touchable for 1-3 seconds). Using a Fluke 87V-MAX multimeter and Type-K thermocouple, I measured the temperatures, confirming the passenger-side hub assembly failure.
With my time in Virginia nearing an end and a strong desire to return west, I enlisted my son’s expertise to replace the faulty hub assembly. After jacking up the truck, we confirmed significant play in the passenger-side wheel by shaking it at the 3 and 9 o’clock and 6 and 12 o’clock positions, compared to the driver’s side. Within an hour, the repair was complete, and I drove away satisfied, grateful for my son’s skillful assistance.
Approaching 100,000 miles on my AEV Prospector, I am planning long-term preventative maintenance, including replacing transmission and transfer case fluid, flushing engine coolant, and checking brake fluid. Using test strips from Phoenix Systems, I measured copper contamination in the brake fluid at 30-100 ppm, indicating no immediate need for a flush. Additionally, I plan to test the brake fluid’s moisture content, as brake fluid is hygroscopic, and increased moisture lowers the boiling point, reducing braking performance and causing corrosion. In my superbike racing days, I flushed brake systems between races to ensure optimal performance.
For historical purposes, I have documented the expenses associated with this work.
The AEV Prospector’s steering knuckle, drag link, and track bar, part of AEV’s High Steer Kit, are custom-engineered components that address longstanding aftermarket suspension challenges. Few companies possess the engineering expertise, OEM connections, and resources to develop such solutions.
If you are interested in a technical discussion related to What It Really Takes to Build a Factory Overlander with Dave Harriton from AEV - here is a great podcast:
ramblinChet
This phase of the project focuses on removing the Four Wheel Camper from my truck bed and fabricating custom-length air lines for my Overland Air Device 145 PSI (OAD-145P). To prepare for camper removal, I first detached two RotopaX 2-gallon water containers from the camper’s front and two 20L Wehrmacht-Einheitskanister (Armed Forces Standard Canisters) from the rear. Next, I installed four Rieco-Titan mechanical camper jacks at each corner of the camper. While some pop-up camper owners keep jacks permanently installed, I remove mine to avoid potential damage from obstacles on rugged trails, which could compromise the camper’s aluminum structure.
When pricing camper jacks, I was surprised to find that a set of four new Rieco-Titan jacks cost just over $1,000, with used units ranging from $700 to $900. I briefly considered designing and building my own jacks but ultimately decided against it. Upon inspecting the Rieco-Titan units, their quality was evident, reflecting decades of engineering refinement. Each jack weighs approximately 25–30 pounds, features smooth and robust internal gearing, and can support up to 2,000 pounds independently. The jacks include manual handles, but I also purchased a $29 drill adapter, which significantly improved efficiency.
Time constraints forced a change in my approach to removing the factory-installed turnbuckles. Initially, I planned to soak them with penetrating oil and use a wrench, but the threaded sections were too rusted. Instead, I used a 4.5-inch angle grinder with a cutting wheel, severing all mechanical connections between the camper and truck in under five minutes. I raised the camper by first elevating the front 2–3 inches, then the rear, using a small level to maintain pitch and roll within acceptable limits. Once the camper cleared the truck bed, I moved the truck forward a few feet, disconnected the electrical harness, and drove out from under the camper. Clearance was tight, with approximately 0.50–0.75 inches between the fender flares, wheels, and camper jacks.
My initial design of the OAD-145P incorporated DOT-approved push-to-connect fittings and SAE J844 tubing, commonly used in heavy-duty trucks. This choice was driven by the availability of replacement components at truck stops. However, after further research and discussions with full-time overlanders, I determined that while cost-effective and easy to assemble, this system lacked long-term durability. I shifted to custom-length air hoses using Continental 3/8-inch rubber air hose and Milton HIGHFLOWPRO brass fittings. Selecting compatible components was challenging, as the outer diameter (OD) of hoses with identical inner diameters (ID) varies significantly. The goal was to choose a brass ferrule that slides over the hose snugly enough to stay in place but loosely enough to allow full insertion of the brass end fitting. Research suggested using soapy water to ease assembly, noting that overly easy insertion could lead to leaks. Even with soapy water and significant force, I could only seat the brass end fitting halfway; a rawhide hammer and several firm strikes fully seated the fittings.
The final step involved selecting the appropriate hardened steel ribbed die for the Heavy-Duty Hose Crimper Tool to crimp the ferrule. This tool accommodates hoses from 1/4-inch single-braid to 3/8-inch two-braid, with die bore sizes of 0.484", 0.531", 0.578", 0.625", and 0.687". While not ideal for all builds, this solution met my need for durable, custom-length hoses capable of withstanding diverse conditions. It will be interesting to evaluate their longevity in real-world use.
The first hose I fabricated delivers air from the OAD-145P inside the camper, through a horizontal surface, to the exterior for distribution. I incorporated a loop in this line to prevent kinking, extend service life, and reduce stress on the fittings.
With the camper off the truck, accessing its exterior was straightforward, allowing me to preconfigure fittings and measure air lines accurately. Masking tape was invaluable for marking and noting measurements on the camper’s flat aluminum surface. For reference, a 1/4-inch NPT (National Pipe Taper) threaded fitting has 18 threads per inch (TPI), so each full turn shortens the assembly by 0.0556 inches along the axis. Initial hand-tightening requires approximately 3–4 turns, with final wrench-tightening adding 1.5–3 turns, resulting in a total axial shortening of 0.25–0.39 inches. This data informed precise hose length calculations before cutting.
The final assembly uses Continental hoses with Parker-Hannifin elbows and tees, Milton ferrules, and HIGHFLOWPRO couplings and end links. Each hose includes a calculated amount of slack to accommodate camper flex during off-road use. Designing and building the OAD-145P was rewarding, and I anticipate reliable performance on the trail. The air line transitioning from inside to outside the camper (visible in the inset image) may require sealant to ensure a weather-tight interface.
For this phase, I documented expenses carefully. I initially considered purchasing the hose crimper from Milton, priced at $276, but opted for a comparable unit that saved over $150. The Klein Tools cutter performed flawlessly, producing clean, perpendicular cuts on the double-braided hose.
Without the camper, my AEV Prospector feels significantly different in both appearance and handling. If I could, I'd trade it all for an automator...
ramblinChet
You didn't replace both front hub bearings?
Negative - the drivers side was tested and is fine right now. There is always a chance it may last another 50k miles although I am prepared to replace it as soon as it begins to degrade.
ramblinChet
The Overland Air Device 145 PSI (OAD-145P) is operational and performing within specifications. Initially pressurized to 145 PSI, the system stabilized at 135 PSI within minutes. This pressure drop is attributed to thermal equilibrium, hose and line expansion, and minor leaks or settling. As compressed air cools to ambient temperature in the aluminum tank and lines, its pressure decreases. Hose and line expansion results from slight stretching under initial pressurization. Minor leaks at fittings or valves are typical in new systems as they stabilize. A pressure loss exceeding 10 PSI per hour in a mature system warrants further investigation. The VictronConnect app, displaying the BMV-712 Battery Monitor, confirms that the 12-volt ExtremeAire Magnum compressor drew a maximum of 82.9 amps and pressurized the system in under 30 seconds, aligning with predictions and establishing a baseline for future measurements.
Electrical connections between the truck and camper are located on the driver’s-side forward wall of the truck bed. The Marnico 70A Trolling Motor Receptacle and Plug, specified four years ago, continues to perform reliably. For 50A DC-DC power transfer between alternators and house batteries, 4 AWG wire connects to a Blue Sea Systems Feed-Through Connector (red). The chassis ground uses 1/0 AWG wire to connect system bus bars to the vehicle frame. Drilled holes for these connections are coated with protective paint for corrosion resistance.
When mounting the 3.5-inch aluminum bracket to the bottom of the aluminum RotopaX carriers, rounded-head screws were initially used. To prevent potential damage to full RotopaX containers from focused pressure, 1-inch x 1/8-inch aluminum flat stock strips, bonded with 3M VHB tape, were installed as a temporary solution. Countersunk flat-head screws are planned for a future upgrade to provide a permanent, damage-free mounting solution.
The chassis ground connection enhances electrical safety, stabilizes voltage reference, and reduces electrical noise. System designers are encouraged to implement a clean chassis ground connection to the vehicle frame. A bolt, cut to length and chamfered using a bench grinder, was used for this installation to ensure a secure and precise fit.
The solar SAE connector, installed on the camper roof by Four Wheel Camper during manufacturing, has performed adequately but will be upgraded to a more robust variant. Additional electrical connections, located below the rooftop connector, are concealed above the wooden lift-assist bar on the camper ceiling.
Installation of four Yakima 60-inch tracks on the camper’s aluminum roof required drilling 44 blind holes into a thin, one-piece aluminum roof supported by 1-inch square aluminum tubing. This complex task required extensive research and consultation, leading to the decision to upgrade components and adopt a precise installation method. Tracks were centered, and distances to the camper’s front and rear faces were measured. Internally, wooden trim strips attached to the underside of the 1-inch tubing were located. A 1/16-inch pilot hole, centered on the strip and piercing the roof, established reference points for track alignment. Tracks were aligned parallel to the camper’s perimeter using percussion testing, temporarily taped in place, and marked with a Starrett automatic center punch. The presence of wood in the outermost beams was confirmed. Pilot holes for outermost beams were 5/64-inch (0.0781"), intermediate holes were 1/8-inch (0.1250"), and final holes were drilled with a #21 bit (0.1590") per the screw manufacturer’s specifications.
Butyl rubber sealing tape (1-1/2") was applied under the tracks, and screws were re-torqued after settling. 3M 5200 marine-grade adhesive sealant was applied to each screw. Unlike standard installations using 24 screws, all 44 holes were utilized with tri-lobular 10-32 x 3/4" Fastite sheet-metal screws, which provide enhanced thread engagement in 0.028" to 0.063" thick sheets, preventing overtightening and thread damage.
The initial Yakima T-bolt screws were incompatible due to overly thick heads; a call to Yakima provided the correct anchor plates for the T-slots. A Newborn 250 caulk gun with an 18:1 thrust ratio was selected for applying the 3M 5200 marine-grade adhesive sealant after researching thrust ratio compatibility. The tri-lobular screws, T25 Torx bit, #21 drill bits, butyl rubber sealing tape, and 3M 5200 adhesive were procured earlier here and here for this installation.
The Yakima tracks were finalized by trimming excess butyl rubber tape flush, ensuring a clean and secure mounting system. Drive like the wind straining the limits of machine and man, laughing out loud with fear and hope I've got a desperate plan...
ramblinChet
Over many months, I have carefully considered the optimal routing for the exhaust from the Wallas Nordic DT diesel cooktop and heater to the exterior of the camper. As a reminder, the Wallas unit is mounted atop the MES-K470 (Modular Energy System housed in a Zarges K470 case), which is densely packed with Victron Energy components. The exhaust must pass through this enclosure before exiting the camper. While it may appear counterintuitive to route diesel exhaust through a confined space containing temperature-sensitive equipment - and indeed, this is likely why no one else has attempted such a configuration - I thrive on these challenges. With decades of experience in designing, fabricating, and commissioning projects deemed impossible by others, I proceeded confidently. Once my exhaust plans were finalized, the only missing component was a straight exhaust pipe. I contacted Chris at Scan Marine USA one final time, and he informed me they had just received straight exhausts, albeit with a curved mounting bracket welded on. This posed no issue; I carefully removed the unnecessary bracket using an angle grinder. The result may not be aesthetically perfect, but it functions reliably.
The subsequent step involved drilling a 45 mm hole through the MES-K470 enclosure, sized to accommodate a high-temperature rubber bushing, a 28 mm stainless steel exhaust pipe, and surrounding exhaust insulation. Ideally, the placement of this exhaust penetration should have been determined during the initial design phase. However, at that time, the only available exhaust option from Scan Marine featured a tube bent 90 degrees relative to the mounting surface, which influenced my early decisions. After drilling, I deburred the edges and thoroughly vacuumed the interior to eliminate any contaminants.
The corresponding hole through the camper wall was drilled at 32 mm. To ensure perfect concentricity between the interior 45 mm hole and the exterior 32 mm one, I first drilled a pilot hole through both surfaces. Another key challenge in penetrating the camper wall was avoiding damage to structural members, wiring, or positioning the exit in a location where exhaust fumes could reenter via a window or door. For verification, I partially disassembled the wall and inspected the corner. To my surprise, the planned location aligned precisely with a 4-inch-wide by 12-inch-tall wooden structural element - ideal for routing the exhaust. This was fortuitous, and I must emphasize that thorough research and planning for exhaust routing should have occurred months earlier. The total exhaust length exceeds one meter, with combined turns not surpassing 180 degrees, ensuring acceptable backpressure for efficient combustion, gas flow, and safety.
Returning my attention to the MES-K470 and finalizing the solar system installation, I removed the new solar panels to shorten their wires and replace the inferior connectors with genuine Stäubli MC4 cable couplers.
Connectors not made by Stäubli which can be mated with Stäubli elements and in some cases are also described as ”Stäubli-compatible” do not conform to the requirements for safe electrical connection with long-term stability, and for safety reasons must not be plugged together with Stäubli elements.
Employing two Stäubli MCR wrenches as part of the assembly process.
A completed Stäubli female MC4 cable coupler. Though it may externally resemble a male coupler, it is the internal contact that designates it as the female variant.
This step required enlarging an existing 24 mm hole to 32 mm to accommodate a Scanstrut cable gland. Despite the provided template, I verified its scale accuracy, as I have encountered issues in the past with imprecise templates leading to errors in drilling or cutting metal.
This view shows the underside from the previous image, now with the Stäubli solar wires routed in and connected to the FWC 10 AWG red and black wires. Notably, the insulation on the Stäubli 10 AWG solar wire was oversized for the Ancor 12-10 AWG butt splices, necessitating creative reinforcement with additional Ancor heat shrink tubing. I operated the solar system in this configuration for two days, monitoring connection temperatures, which remained within acceptable limits. The inset image depicts the Stäubli solar wires before splicing; my objective was to confirm polarity to ensure correct connections and prevent damage to the solar charge controller.
All expenses continue to be documented for reference.
Here, I am marking the solar panel frames prior to drilling four mounting holes in each of the two panels. To achieve precise hole placement at both ends of each panel, I accounted for tolerance stacking - the cumulative effect of individual dimensional variations in an assembly that can affect overall fit, function, or performance. In this instance, I drilled four sets of holes at varying widths (55.875", 55.625", 55.688", and 55.375") across a 64" span, indicating the tracks were not perfectly parallel. Extrapolating these measurements along the full 120" length of both tracks suggests each track deviates approximately 0.46875" from true center. My initial pilot holes were centered precisely on the underlying wood strips, though I acknowledge the exit points one inch higher through the roof may have been offset by up to 0.125". At the rear, my percussion testing could have introduced up to 0.250" error, so I attribute 0.280" of the 0.46875" discrepancy to my measurements, with the remainder belonging to FWC fabrication tolerances.
Here is my calculation for my portion of the error: (1) identify individual tolerances: 𝑡1=0.125 and 𝑡2=0.250 (2) square each tolerance: 𝑡1²=0.015625 and 𝑡2²=0.0625 (3) sum the squares: 0.015625+0.0625=0.078125 (4) take the square root: √0.078125≈0.280 (5) thus, my bilateral stacked tolerance is ±0.280 and FWC owns the balance. As evidenced, I approach such matters quantitatively, with a deep appreciation for numerical precision.
ramblinChet
These solar panels may be the only ones installed on a camper with tolerances optimized to a thousandth of an inch. Precision reflects a commitment to quality, accuracy, and reliability, which is critical in engineering, manufacturing, and design, where tight tolerances can significantly affect performance, safety, and efficiency. However, excessive precision can lead to diminishing returns, wasted resources, or decision-making paralysis. On this personal project, I prioritized high precision, as I am funding the labor and find the exercise rewarding. In contrast, when managing external budgets, I adopt a professional yet practical level of precision to balance cost and quality.
A minimum 4-inch gap beneath and between the solar panels ensures adequate airflow, dissipating heat generated during operation. Research, including solar engineering studies, indicates that a 10–15 cm (4–6 inch) gap can reduce panel temperatures by 5–10°C compared to flush-mounted panels, depending on wind speed and ambient temperature. Solar panel efficiency typically decreases by 0.3% to 0.5% per degree Celsius above the standard test condition of 25°C (77°F), based on the panel’s material and design. These panels have a temperature coefficient of power of -0.39%/°C, typical for high-quality monocrystalline panels. The panels are connected in series using high-quality Stäubli MC4 connectors.
One design goal was to mount both panels as close as possible to the roof’s centerline, which slightly conflicted with the objective of maximizing airflow around the panels. Calculations showed that positioning the panels 4 inches forward from the ventilation fan would have a greater impact on lifting the camper roof’s front than the minor power loss from reduced cooling. The 500-watt solar array exceeds my power requirements, which was intentional to ensure ample capacity.
To address excessive condensation from cold weather, which can lead to mold, rust, and material degradation, I replaced a propane heater with a diesel heater. Diesel heaters produce dry heat, reducing indoor moisture. During this upgrade, I replaced twelve rusted screws and finish washers with stainless steel equivalents, costing $10–15 and requiring approximately 10 minutes of labor.
Installing a new fire and carbon monoxide (CO) detector with a 10-year sealed battery significantly enhances camper safety. Diesel heaters, while efficient, can produce CO, a colorless, odorless, and potentially lethal gas. In a confined camper space, CO buildup or fire risks from heater malfunctions are critical concerns. The long-life battery ensures reliable operation during off-grid travel, providing peace of mind and compliance with safety standards. This cost-effective upgrade is essential for camper safety.
Four Sealcon glands are being installed: two within the Modular Energy System K470 (MES-K470) and two in the bed of the AEV Prospector. These glands facilitate the passage of the diesel fuel line and five wires from the MES-K470, through the camper’s side, and into the truck bed. Three wires connect to the fuel level sensor, while the remaining two extend along the frame to the auxiliary Power Distribution Center.
The main image shows the upfitter connectors (dark and light gray), which are part of the auxiliary Power Distribution Center, on the firewall near the brake booster. These connectors, part of the vehicle’s upfitter wiring kit, use eight wires with 1/4-inch blade terminals. Controlled by six auxiliary switches in the cab, the connectors can be programmed via the Electronic Vehicle Information Center (EVIC) for battery or ignition function, momentary or latching operation, and state retention (for ignition mode). My auxiliary switches are configured as follows:
  1. Diode Dynamics 30-inch front bumper light bar
  2. Diode Dynamics A-pillar lights
  3. Baja Designs rear bumper chase lights
  4. ExtremeAire Magnum compressor activation
  5. Victron Energy Orion XS 12/12-50 DC-DC charger activation
  6. BD Diesel 2 Low UNLOC engagement
Expenses for this phase of upgrades are being documented.
Since the AEV Prospector did not have the camper installed, I weighed the vehicle on a certified scale at a truck stop. The results, compared to previous measurements, are as follows:
  • June 2021 (6,475 lbs)
    • Stock vehicle, no AEV Prospector package or Four Wheel Camper
  • October 2022 (8,660 lbs)
    • AEV Prospector package and Four Wheel Camper installed
    • Front axle: 4,640 lbs
    • Rear axle: 4,020 lbs
  • August 2025 (7,260 lbs / 7,089 lbs adjusted)
    • AEV Prospector package installed, no Four Wheel Camper
    • Front axle: 4,460 lbs / 4,355 lbs adjusted
    • Rear axle: 2,800 lbs / 2,734 lbs adjusted
    • Adjustments:
      • PEWAG tire chains: -141 lbs
      • AEV full-size trail recovery kit: -56 lbs
      • Deadman recovery kit: -10 lbs
      • Six gallons of gasoline: +37 lbs
The data indicates that the AEV Prospector package added 614 pounds, while the Four Wheel Camper and additional gear contributed 1,571 pounds as of October 2022. The stock RAM 3500 chassis had a Gross Vehicle Weight Rating (GVWR) of 11,000 pounds and a payload capacity of 4,529 pounds. The AEV package (614 lbs) and Four Wheel Camper with gear (1,571 lbs) consumed 48% of the payload capacity. In October 2022, the fully loaded AEV Prospector retained 2,340 pounds of available payload. I plan to reweigh the vehicle once the camper is reinstalled to confirm these figures. Can't we give ourselves one more chance?
Pacific Northwest yetti
Expedition Medic
Would not be a bad time to check your fire extinguisher as well. Or replace the plastic OE one with a metal, rechargeable and rebuildable one. The powder ends up settling in the bottom and getting hard. The gauge may still show as green. But if you flip it upside down, you should be able to feel and hear the powder shift inside.
ramblinChet
You may recognize these Schwaben Ear-Type Clamp Pliers, designed for use with Oetiker clamps in automotive and industrial applications. Oetiker clamps provide uniform compression, compensate for component tolerances, and enable fast, reliable installation. To select the correct clamp diameter, install the hose onto the fitting and measure the hose's outer diameter (OD). The measured OD should be slightly larger than the average value of the clamp’s diameter range. A clamp is adequately closed when the ear width is reduced by at least 40% using the appropriate closing force. For my project, I needed only a foot of fuel hose but opted for a 25-foot roll of Continental 3/16" ID Fuel Line/Emission Control Hose (SAE 30R7). This hose, constructed with Hysunite and Chemigum, is rated for temperatures up to 250°F and offers versatility for multiple applications.
Ear-Type Clamp Pliers function by crimping Oetiker ear clamps to create a secure, leak-proof seal on hoses or tubes. The user positions the clamp around the hose and fitting, then places the pliers’ jaws over the clamp’s ear. Squeezing the handles applies precise force, deforming the ear to reduce the clamp’s diameter and lock it in place. Engineered for uniform compression, these pliers ensure a reliable 360° seal. Their jaw configurations accommodate various clamp sizes and are designed for use in confined spaces.
This image illustrates the transition from an accessory to the 5mm OD, 2mm ID fuel line used by Eberspächer, Wallas, and Webasto diesel heaters. Here, I connect a Hengst Filtration diesel fuel filter to the Continental 3/16" ID hose, secured with two Oetiker clamps at each end for a robust, leak-free connection.
I also incorporated a premium quick-disconnect for the diesel fuel line to allow easy removal of my camper without fully disconnecting the fuel line from the truck’s fuel tank or the diesel heater inside the camper. I selected a Goodridge chrome-plated brass quick-disconnect for $100 (shipped) and am eager to evaluate its performance. The Continental hose and Oetiker clamps bridge the disconnect to the standard fuel line, ensuring a secure connection.
Removing the 30-gallon TITAN auxiliary fuel tank from beneath my truck was a daunting task, and reinstalling it after adding wiring, a vent hose, a rollover hose, a primary fill hose, and trimming everything to length was equally challenging. I recall the initial tank installation, which was difficult even with a friend’s help. This time, I completed the task alone, making it even more demanding.
B’laster Surface Shield provides robust protection for a truck’s undercarriage with its lanolin-based formula, effectively preventing rust and corrosion in harsh environments, such as salt-heavy roads. Its moisture-wicking properties form a durable barrier against water and contaminants, offering protection for up to two years. Compared to alternatives like Fluid Film or Woolwax, Surface Shield applies cleaner, is less messy, and adheres better in high-wash areas while remaining safe for rubber, plastics, and electrical components. Its low viscosity ensures excellent creep into crevices for comprehensive coverage, and its non-drying, tacky film resists wash-off, making it ideal for rugged, off-road conditions. I regret not applying this product years ago. In March, I ordered six cans of Surface Shield and two Can-Gun1 spray handles, which provided ample product and performed exceptionally well during application.
Innovative projects often present unique challenges requiring creative solutions. To mount a universal fuel pick-up tube with ears and male M18x1.0mm threads into a double-tapped tank bushing with 1" NPT male and 1/2" NPT female threads, I rejected the simplistic approach of plugging the 1/2" NPT female hole and drilling a new one elsewhere. Instead, I purchased a 1" NPT brass hex head plug, a 17mm drill bit, and an M18x1.0mm tap. I drilled and tapped a hole in the brass hex head, removed the silver solder, knocked off the mounting ears, cleaned the threads, and sealed the modified components with yellow gas-line PTFE tape. This solution ensured a precise, professional outcome.
I’m an ordinary guy with a few close friends, including one I worked with at Siemens VDO and later at NASA Langley Research Center. He’s the finest mechanical engineer I’ve ever known, currently serving as a Senior SME Principal Mechanical Engineer at NASA Langley. With a shared sense of precision, he invited me to his shop to drill, tap, and trim the fuel pick-up for my diesel heater. While there, he showed me his special cutting oil, a can he’s owned since he was 16, working in a small engine repair shop to save for university. An older colleague gifted him the can and wished him well - a gesture from half a century ago. This story reminds us that a small act of generosity can profoundly impact someone’s life.
Here, I continue documenting expenses for historical reference.
The fuel pick-up (tank fitting) is now installed, and I expect it to perform reliably. The fuel pump in a Wallas Nordic DT diesel heater, a low-pressure electric pump designed for compact marine or RV heating systems, faces significant challenges when drawing diesel through a hose with an inner diameter (ID) greater than 2mm to a height of six feet. The pump’s limited suction capacity, optimized for 2mm ID hoses and shorter lift heights, struggles with the increased volume and flow resistance of a larger hose. A hose with a >2mm ID demands greater vacuum pressure to overcome the fuel column’s weight, which increases with both height (six feet creates substantial static head pressure) and the hose’s larger internal volume. Additionally, the pump risks cavitation or air ingress due to insufficient priming or sealing, reducing efficiency and potentially stalling. These factors - insufficient vacuum strength, increased fuel weight, and potential air ingress - make consistent fuel flow difficult. This is why I invested extra effort to install a fuel pick-up with a 2mm ID. The inset picture compares the original fuel pick-up to the one I constructed. I hope this solution succeeds, as it operates near the fuel pump’s performance limits. Function is the key...
ramblinChet
All parallel upgrades and modifications are rapidly converging, nearing a point where the system will become fully operational with remarkable seamlessness. The Sealcon glands in my truck bed now accommodate one diesel fuel line and five electrical wires. The fuel line supplies diesel to the Wallas Nordic DT diesel cooktop/heater. Three wires connect to the fuel level sensor, while the remaining two are 12-volt signal wires: one activates the air compressor from the cab, and the other controls the Victron Energy Orion XS 12/12-50 DC-DC converter, also from the cab.
All connections from the camper are positioned adjacent to their corresponding connections from the truck, as viewed from inside the camper, which has been remounted. I intentionally left the connections slightly longer to avoid the need to remove the camper and extend lines later. Trimming a few inches once everything is in place is simpler than adding length. My objective was to ensure all connections are easily accessible through one of the turnbuckle access doors in the Four Wheel Camper.
While removing my camper approximately one month ago, I inadvertently failed to disconnect the Low-Voltage Differential Signaling (LVDS) cable. This digital serial interface supports high-resolution video over a single shielded coaxial cable, typically equipped with a FAKRA connector, offering superior signal integrity, reduced noise, and higher-quality imaging compared to older analog composite systems. This oversight resulted in a $90 repair cost but, fortunately, required only a few hours to rectify.
With the camper remounted and the auxiliary diesel fuel system fully operational, I conducted a shakedown run late in the evening, transferring ten gallons of diesel into the 30-gallon auxiliary tank mounted under my gasoline-powered truck. At the Mobil station, I approached the counter, paid $40 in cash, and requested diesel fuel for pump nine. When purchasing diesel south of the Mason Dixon it's important that you pronounce "diesel" properly by drawling it out with a rugged, low tone, emphasizing the grit in your voice. Say "DEE-zul": Break it into two syllables. The first part, "DEE," is sharp and slightly elongated, like you’re spitting it out. The second, "zul," is short, gruff, and drops low, almost like a growl. Lean into a Southern twang. Let the "DEE" linger a bit, like "DEEE-zul," but don’t overdo it - keep it tight, not sing-songy. And finally, speak from your chest, not your throat. Add a gravelly edge, like you’ve been chewing tobacco and yelling at cattle all day. Think Clint Eastwood squinting in the sun.
"With an anxiety that almost amounted to agony, I collected the instruments of life around me, that I might infuse a spark of being into the lifeless thing that lay at my feet. It’s alive! It’s alive!" ~ Frankenstein (1931)
The fuel level registered at 35%, precisely as expected, and the Wallas controls and heater are fully operational. All systems have been verified and are functioning correctly, confirming readiness for full operation.
My Mountain Hardwear sleeping bags, now fifteen years old, have exceeded their expected lifespan but continue to perform reliably. The three-season bag sustained another tear, which I repaired using Tenacious Tape repair tape, a product I’ve had in my inventory for approximately 10–12 years. The repair was successful, restoring the bag’s functionality.
My AEV Prospector with Four Wheel Camper, fully loaded, weighs 8,960. GVWR is 11,000; original payload was 4,529. AEV Prospector upgrade added 618 pounds, Four Wheel Camper and accessories added 1,871. Actual payload is 2,489 so I am using 55% of available payload (2,489/4,529). Perfect.
Documentation of expenses for this phase of upgrades and repairs.
As a traditional Catholic devoted to the Latin Mass, I discern the hand of Divine Providence in the feather that gently settled on my windshield moments before embarking on a long and treacherous journey alone. This delicate sign, perhaps from my guardian angel or a beloved soul now in heaven, speaks of God’s tender protection. In the sacred communion of saints, I am reminded that I am never truly alone, strengthened by the intercession of the Immaculate Heart of Mary and the ever-watchful love of the Almighty, guiding me safely on my path.
And the road becomes my bride...rover, wanderer, nomad, vagabond. Call me what you will.
ramblinChet
Mid-Atlantic Backcountry Discovery Route
Part One of Three
The Mid-Atlantic Backcountry Discovery Route (MABDR) is a thrilling 1,080-mile off-highway adventure crafted by the nonprofit Backcountry Discovery Routes organization specifically for dual-sport and adventure motorcycles, weaving through the remote, historic, and scenic landscapes of Virginia, West Virginia, Maryland, and Pennsylvania. Beginning in the charming town of Damascus, Virginia, near the Appalachian Trail, the route kicks off with winding dirt and gravel paths through the George Washington and Jefferson National Forests, progressing northward via a balanced mix of challenging backcountry trails, rural paved roads, and technical sections like the twisty Tub Run Road, all while offering sweeping mountain vistas, dense hardwood forests, rolling farmlands, Amish communities, and historic battlefields. Drivers encounter diverse terrain that demands attention to ruts, washouts, and seasonal changes, with opportunities to explore cultural landmarks and even recharge at cozy lodgings along the way, ultimately delivering an immersive 9-12 day journey into the natural beauty and heritage of the Appalachian region.
Following months of modifications and upgrades to my AEV Prospector and FWC pop-up camper, it felt great to be back out in the wild. My adventurous soul is like a restless flame, forever flickering toward the horizon where the known meets the unknown. It is not merely a desire for movement but a deep, unshakable yearning to uncover what lies beyond the next ridge, to taste the air of primitive lands, and to feel the pulse of the world in its rawest form.
Hurricane Helene, which struck in late September 2024, caused catastrophic flooding and destruction across western North Carolina, eastern Tennessee, and southwestern Virginia, damaging infrastructure like roads and bridges. The first section of the MABDR dances between North Carolina, Tennessee, and Virginia.
While exploring sections two and three of the MABDR you will find yourself in the rugged Appalachian terrain of Virginia and West Virginia, weaving predominantly through the majestic George Washington and Jefferson National Forests (GWJNF). Originally named the Shenandoah National Forest and later renamed for America's first president, the GWJNF expanded with the addition of the Jefferson National Forest preserving over 1.8 million acres wilderness composed of sweeping vistas of ancient hardwoods, wildflower meadows, and historic mountain passes that once served as a backdrop for Revolutionary War and War of Northern Aggression.
Overland travel does not necessitate continuous dirt or gravel roads, as paved backcountry or farm roads often interrupt these rugged stretches. In today’s age, maintaining an unbroken journey of over a thousand miles solely on dirt is nearly impossible due to modern infrastructure. These paved connections, weaving through rural landscapes, allow travelers to sustain the spirit of overland exploration while navigating a mix of surfaces with the spirit of adventure and self-sufficiency.
Overland travel often involves equipping campers with solar panels to harness the sun's energy, but properly mounting them four inches above the roof for optimal cooling and solar efficiency presents challenges. This elevated setup enhances airflow maximizing power output, which is critical for off-grid adventures. However, it increases the risk of snagging low-hanging branches or fallen trees on rugged trails, potentially slowing progress or causing damage. Despite these obstacles, the improved solar efficiency typically outweighs the risks, as reliable power is essential for extended overland journeys, making the raised mounting a worthwhile trade-off.
Just down the road from Mountain Lake Lodge in Virginia, where the iconic 1987 movie Dirty Dancing was filmed, a stunning vista reveals the Blue Ridge Mountains in their splendor. The rolling peaks, draped in a misty haze, stretch across the horizon, their blue tint stemming from isoprene released by the dense forests, scattering sunlight to create the signature glow. This serene scene, with lush greenery in the foreground and the majestic, blue-tinged ridges in the distance, offers a tranquil escape steeped in natural beauty.
In Warm Springs, Virginia, the historic Warm Springs Pools beckon with their mineral-rich hot and warm springs, a 19th-century haven I plan to visit again someday for a soothing soak. As I travel north, I enter the National Radio Quiet Zone, created in the 1950s to protect the Green Bank Observatory’s radio telescopes and the highly secretive naval listening post at Sugar Grove, whose covert intelligence-gathering mission - rumored to involve a sprawling underground city beneath the base - sparks whispers of hidden operations. This 13,000 square-mile zone disrupts cellular service, leaving travelers without calls or data, though passive GPS navigation remains mostly unaffected.
Tub Run Road on the MABDR meanders through a lush, healthy forest where vibrant green trees create a tranquil canopy overhead. Sunlight weaves through the branches, casting soft light on the path below. The road’s continuous twists and turns, particularly along the narrow shelf sections, cling tightly to the rugged terrain, offering a thrilling yet serene ride. Each curve reveals a fresh glimpse of the wilderness, blending the excitement of exploration with the calming beauty of dense, untouched nature that feels both timeless and alive.
As a traditional Catholic who cherishes the solemnity of the Latin Mass, I often reflect on how we men struggle to consciously embrace the internal challenges that demand risk and danger, our fallen nature pulling us toward the safety of complacency rather than the forge of trials that temper the soul. This mirrors the trepidation one feels when venturing alone into the dark embrace of the forest at night, where shadows whisper uncertainties and the unknown path tests one's resolve - much like choosing to tackle the rugged, optional challenge of Hite Hollow Road on the MABDR, a demanding stretch that beckons the adventurous spirit to confront isolation and peril head-on. Yet, the more we fully surrender ourselves and our lives to ************************, the more profoundly protected we become, for our time on earth is but a fleeting moment, our sacred chance to redirect our eternal trajectory toward the glory of Heaven. Godspeed Charlie...
ramblinChet
Part Two of Three
The last 75 miles of MABDR Section 3 offer a thrilling mix of rugged terrain and scenic backcountry riding, highlighted by a half-dozen water crossings that must be navigated with care. On average, these crossings are around six inches deep, though they can swell to one foot or more due to weather conditions, making it essential to assess water levels before proceeding. Throughout this section and others on the MABDR, fuel availability is limited, often requiring drivers to plan ahead; however, a reliable option is the Sunoco station in Brandywine, West Virginia, which offers Top Tier gasoline. To bolster my fuel security, I carry two Wehrmacht-Einheitskanisters, each holding 20 liters (5.3 gallons) for a total of 40 liters (10.6 gallons) of emergency fuel for extended stretches without stations.
The MABDR winds through the breathtaking Spruce Knob–Seneca Rocks National Recreation Area in West Virginia, offering riders a stunning blend of rugged landscapes and iconic natural landmarks. This section showcases three major areas of interest: (1) Spruce Knob, the highest point in West Virginia at 4,863 feet, provides panoramic views from its observation tower, revealing rolling Appalachian ridges and serene valleys, perfect for a scenic pause. (2) Seneca Rocks, a dramatic 900-foot-tall Tuscarora sandstone formation, towers over the North Fork Valley, attracting climbers and sightseers with its jagged profile and nearby visitor center offering historical insights. (3) Smoke Hole Canyon, carved by the South Branch Potomac River, features deep gorges, limestone caves, and lush forests, creating a remote and tranquil setting ideal for exploration. Together, these landmarks make this stretch of the MABDR a highlight for adventure riders seeking natural beauty and geological wonder.
Riding through the thick forest on the MABDR, I started seeing single power lines on old poles, a sign that a town was close by. A few miles later, the trees opened up to wide farm fields under a big blue sky, with cattle grazing peacefully, welcoming me back to open country. It felt good to roll out of the wild and into civilization again. Soon, I pulled into Petersburg, West Virginia, a historic town founded in 1745 with some Civil War history. At The Hermitage Inn & Taphouse, I stopped for a solid lunch on their shaded porch where my adventure vehicle caught the eye of everyone sitting outside. The waitress, super friendly and a bit flirty, made the meal even better, and I left her a great tip, though she seemed disappointed I was just passing through on my journey.
The MABDR (Section 4) cuts through Green Ridge State Forest (GRSF) after crossing the Potomac River over the Old Town Toll Bridge, a historic low-water wooden bridge built in 1937, connecting Green Spring, West Virginia, to Old Town, Maryland. I’ve crossed this bridge several times over the past seven years, always hearing the wooden boards slap under my tires while taking in the scenic river views. GRSF is Maryland's largest contiguous public land at 49,000 acres, boasting over 80 miles of trails for hiking, biking, and horseback riding; and the Paw Paw Tunnel, a 3,118-foot C&O Canal feat from 1836-1850, boasts nearly six million bricks. I’m considering creating and submitting an alternate hard route through GRSF with 3-5 Town Creek crossings, averaging 1.0-1.5 feet deep, for a tougher challenge. This section of the MABDR offers the Antietam/Harpers Ferry Bypass, which I suggest taking unless you plan to visit Antietam, site of the brutal 1862 War of Northern Aggression battle with 23,000 casualties, and Harpers Ferry, where John Brown’s 1859 raid fueled pre-war tensions; the bypass saves about 17 miles and 30-45 minutes, while the main route is mostly paved through these historic sites.
Way down in the blue ridge mountains
Way down where the tall pines grow
Lives my sweetheart of the mountains
She’s my little Georgia rose
Properly mounted and aimed off-road lights are invaluable for night riding on trails - casting powerful beams that cut through the darkness to reveal the road’s texture and obstacles ahead. My setup, featuring a 30" lightbar, fog lights, and ditch lights, all from Diode Dynamics, delivers high-intensity LED illumination that highlights ruts, rocks, and dips by creating sharp shadows, giving me a clear view of the terrain’s contours and depth. These lights define the trail’s surface helping me adjust speed and steering to tackle the path with confidence.
I have always enjoyed cruising on the trail at night - this snapshot captures a smooth, well-graded gravel road bathed in the glow of my light system, revealing a surface so even and free of obstacles that it invites a confident boost in speed. The LED beams cast crisp, shadow-free light across the trail, highlighting its flat, hard-packed texture - no ruts, rocks, or loose gravel to slow me down. This stretch feels like a rare treat on the rugged route, letting me open up the throttle and glide through the cool night air with ease, the illuminated path stretching ahead like a promise of smoother miles.
As I crossed from Maryland into Pennsylvania, I entered Michaux State Forest, a vast 85,000-acre woodland that once concealed Camp Michaux, a top-secret WWII POW interrogation camp where over 7,500 German prisoners passed through, including high-level officers from the German U-boat fleet, Afrika Korps, and even the inventor of the V-1 Buzz bomb, whose interrogations aimed to uncover vital secrets about Nazi weaponry and strategies. The camp's remote setting near Washington, D.C., made it ideal for extracting intelligence, and notably, the German POWs proved so trustworthy and respectful that in many U.S. camps, including aspects of operations here, they were permitted supervised visits to nearby towns, fostering a sense of mutual respect amid the wartime tensions. The forest features dramatic elevation shifts from about 600 feet in the valleys to over 2,000 feet on the ridges. Enhancing the trail's camaraderie, local neighbors stock coolers with cold drinks and snacks for BDR riders, much like the support given by "trail angels" to Appalachian Trail hikers who overlap this route.
While riding the Trans-Pennsylvania Adventure Trail from north to south in March, I stopped to photograph Long Pine Run Reservoir in Michaux State Forest, a 151-acre lake that was shockingly low at just 45% capacity, its muddy banks exposed due to a dry winter and low rainfall. The scene was a stark contrast to the lush forest around it. Now, months later, on my south-to-north MABDR journey, I passed by again and found the reservoir brimming, several feet above normal levels, thanks to heavy spring rains in April and May, restoring the water supply for Chambersburg and bringing the lake back to life. Seeing such extreme fluctuations makes me wonder if the significant changes in weather patterns over the past decade or so could be tied to weather control efforts, which have historically been explored as a form of warfare - like the US military's Operation Popeye during the Vietnam War, where cloud seeding was used to prolong monsoons and disrupt enemy supply lines.
A few days back, I’d texted my buddies Paul and Matt, who’d started the MABDR nearly two weeks ahead of me, and learned they were camped near Pine Grove Furnace State Park, a historic spot dating back to 1764 with its iron furnace and now famous for the Appalachian Trail’s half-gallon ice cream challenge, where hikers celebrate the trail’s midpoint by downing a tub of chocolate or vanilla. Cruising northbound on Ridge Road, I was stunned to see the rugged silhouette of Paul’s RAM HD with a Four Wheel Camper barreling toward me, kicking up a dust cloud that partially hid Matt’s full-size Chevy trailing close behind. I hadn’t shared trails with Paul since we traveled through Arkansas and Oklahoma last year, and it’d been since Overland Expo East 2023 that I’d last seen Matt. We pulled over, swapped stories, and they mentioned upcoming appointments at Main Line Overland in West Chester, Pennsylvania, to tweak their rigs in a few days. Listening to my little Georgia rose as we met on the trail fired me up - what other surprises and thrilling moments awaited on the next leg of this wild ride?
ramblinChet
Part Three of Three
It was early 2023 when I met Paul in the Ocala National Forest, Florida - having just helped an LMP3 team win the Rolex 24 at Daytona, I was eager to escape for some well-deserved rest in the wild. Paul, wintering in Florida, had a Palomino camper that struggled with heavy use, and I joked that his Power Wagon needed a Four Wheel Camper upgrade. Earlier this year, he called, and after some discussion, he purchased a well-appointed FWC Hawk. Now, on the MABDR, we camp side by side in Michaux State Forest, Pennsylvania, our campers nestled in a serene, tree-lined clearing.
Though 95% of my time in the forest, mountains, or desert is spent alone - I'm now making more of an effort to connect with friends and create lasting memories while adventuring. Solo travel offers the freedom to set my own pace and explore personal interests, fostering self-reliance and reflection, ideal for wild terrain. Yet, it brings risks like no backup, meticulous planning, and occasional loneliness in remote areas. Embracing both solitude and responsibility requires preparation. Tonight, under the red glow of our campsite in the forest, it was nice to sit with Paul and Matt, share a meal, and swap stories and discuss future plans.
Under the glow of his headlamp, Matt cooks up a hearty meal on his trusty Chevy Silverado 1500, a versatile truck that's powered his adventures for years despite its payload limits. We met a few years back camping side-by-side at Overland Expo, bonding instantly as military vets. To maximize space, Matt installed a TopperEZLift - an all-electric 12V roof-lift system that transforms a standard fiberglass camper shell into a pop-up sleeping platform, with ventilation through zippered windows, and easy gear access. However, exceeding the payload limit has led to a series of unexpected issues, prompting Matt to hint at seeking a new truck to build in the future.
Dust on the trail, especially rugged stretches, poses a significant challenge, forcing groups to spread out over great distances to avoid clouds that obscure visibility and coat everything in a fine layer. Trucks following behind the leader get blanketed in dust, while their air intakes pull in particles for hours; conditions these systems aren’t designed to handle. A snorkel, like the AEV Snorkel Kit, sometimes elevates the air intake above the dust cloud, and pairing it with the Sy-Klone, a self-cleaning circular pre-filter, traps up to 99.9% of debris via centrifugal ejection. Additionally, dust coating solar panels can slash their efficiency reducing output by 5-10%.
Stretched out across the road, this beautiful black rattlesnake caught my eye, basking in the sun with its shiny dark scales. I stopped my truck to take a closer look, but as I stepped closer, it slithered off and coiled up tight, tail buzzing loud as it reared into a strike pose, those eyes locking on like I’d crossed a line. I eventually backed off, giving it space to settle, a reminder to watch my step around these wild guardians who’d rather flee than fight. In case you are interested; in Pennsylvania, a handful of small towns still host annual rattlesnake roundups where participants capture timber rattlers for prizes like longest or heaviest snake, before releasing them unharmed back into the wild.
The 250-mile stretch of the MABDR through Pennsylvania, from the Maryland border to the New York state line, is, to me, the most beautiful part of this journey, winding through stunning state forests like Tuscarora, Rothrock, and Bald Eagle. Trust me, when you travel north of Interstate 80 in central Pennsylvania, it feels like stepping back in time - quiet trails and untouched woods that take your breath away. Here, our trucks parked in this lush forest campsite, we soak in that timeless peace under a canopy of green and gold.
Along the MABDR in Pennsylvania, this farm comes into view with a herd of sheep grazing on the hillside. It’s a quiet nod to the state’s sheep industry, where thousands of family farms raise flocks for lamb, wool, and milk, supporting rural life amid the backcountry. Seeing them graze offered a calm break from the trail.
This picture of a rocky incline on the trail brings back a mistake that still sticks with me. Two of us tackled the tougher optional connection, while the third stayed on the primary trail; we agreed via radio to meet where the trails merged again. Sadly, the solo traveler used an outdated GPX file and with our radios’ limited range and no cell service, we lost touch fast on this mountainous stretch. It took nearly an hour to reunite, and I’m still puzzled why we drifted so far. Reflecting on it, we should’ve stopped, stepped out, compared maps, and set a primary meeting point with a time. We also needed a backup spot further along, agreeing to wait there if the first failed, ensuring we’d regroup no matter what.
Encountering flat tires while overlanding can transform a scenic trip into a challenge, especially in the wild where help is hard to find. At a high elevation along the trail, Paul wrestled with a stubborn flat that tested his patience, struggling to loosen the OEM lug nuts that seemed to swell under the reduced atmospheric pressure - likely due to the sealed chrome covers reacting to the altitude. He tried the factory 7/8-inch breaker bar, but it wouldn’t fit the nut, and a 15/16-inch socket just spun uselessly. Driving down to a nearby town eased the pressure, and the lug nuts returned to normal size, the chrome covers shrinking as the air thickened - a clear sign of altitude’s quirky effects. Moving forward, I’m swapping my OEM lug nuts for solid aftermarket ones to avoid this headache in the future.
The 1,080-mile MABDR was a rugged blend of towering forests, historic passes, and unexpected challenges, with the 250-mile Pennsylvania stretch standing out as my favorite for its timeless beauty north of I-80. Encounters like the black-phase rattlesnake’s warning, a sheep farm’s quiet graze, and dust scattering our group tested our grit, while Matt’s payload-strained Chevy and Paul’s high-elevation flat honed our skills. Reunions with Paul and Matt for meals and stories warmed the solitude, reflecting my solo travel musings, and the trail’s demand for surrender echoed a deeper faith. Camping near this final site under a dusky forest canopy, with gear strewn like memories, felt like a sacred pause; the rustling leaves offered a fitting goodbye as they head home for a month and I move to the next trail, carrying lessons of synced maps and backup plans. Now, boys, don't start your ramblin' 'round...
