Doc's 05 Tacoma Build Thread
Dave Bennett
Adventurist
What group number is your new battery?
From the Sears website:
Sears said:
The P-5 Platinum Automotive Battery Group Number 35 from DieHard offers 100 minutes of reserve capacity and 740 cold cranking amps.
http://www.sears.com/shc/s/p_10153_12605_02850035000P
The P5 is 10 lbs lighter than my huge Odyssey 1700 (50 lbs vice 60+) so I am saving a wee bit of weight up front by moving the Odyssey amidship.
For those wondering, the Sears Die Hard Platinum P2 will also fit in the stock location.
Dave Bennett
Adventurist
Power Pack Upgrade and Viair Install Phase 1
Today I upgraded the battery in my National Luna Power Pack from my old OEM Toyota battery to the Odyssey PC1700 MJT.
I also started fitment of my Viair 400C air system back there in the FlipPac, more on that install later. As you can see, air and power are pretty much a non-issue now ;)
Here is a pic from today:
Dave Bennett
Adventurist
Camper Upgrades
Part of my total power upgrade, the Die Hard Platinum P5 under the hood with new OEM Toyota battery tie down waiting for the new Blue Sea 12 circuit negative bus fuse block and some housecleaning on several years of add on wiring...
*Also note the red 3/8 fuel line coming down from the oil filter mount. This attaches to the drain nipple there and I use that hose to direct any leftover oil from the filter to a container during oil changes.
The ARB X-Jack and my big medical kit have a nice home along the wall of the FlipPac, and I moved the Engel display closer to the fridge and added a magnetic strip from Ikea that can hold various kitchen bits
Note the magnet below the bottle opener to catch bottle caps and the cup from Ikea that serves as catch all in camp as well as a cup holder. Also added the RV level to make spotting and leveling the camper easier.
WASURF63
Nice job on the "total power upgrade"! Are you running all your house power to the NL power pack, keeping the winch and aux driving lights tied to the starting battery, or some other combo?
The X-Jack looks alot more compact than a hi-lift, and safer too.
I like the addition of the RV level. I've been using two levels inside the cab, one level just below my dash and one on the B-piller for a few years now.
I also carry two Fiamma Level-Up ramps to alleviate looking for rocks, especially in the dark. If my camp site isn't level, I make it so.
Decide on a water storage/delivery system yet?
Dave Bennett
Adventurist
Yes, all "house power" needs like fridge, LED lighting, and air compressor are drawn from the NL power pack.
Winch, Lightforces, stereo, CB, and any future in-cab power needs will all be drawn from the Die Hard Platinum/OEM charging system under the hood.
The X-Jack is a really slick piece of gear. Lighter and safer than a Hi-Lift and easier to carry, it does it all.
I have a Lev-O-Gauge in the cab as well as the RV level in back. I need to get some of those level up ramps since rocks can be a PITA...
I'm still looking, key for me is fitting it in where I have space. Equipt has a really nice footwell water tank and a couple other options from Frontrunner that look promising. AT has one hell of a hot water shower system too.
All in good time, I'm running out of things to add... ;)
bendersfab
Supporting Sponsor
The X-Jack looks alot more compact than a hi-lift, and safer too. [/QUOTE]
You should still carry both just in case your vehicle decides to stop running or breaks down and will not pump exhaust to fill the Xjack. Plus for better safety, a HighLift jack should be used along with it.
Unless they can be filled with air also??
I don't own one, but like the concept also. :)
Dave Bennett
Adventurist
You can use an air compressor to fill it up too. My Hi-Lift lives in the garage now.
HMR
Rendezvous Conspiracy
+1. I see absolutely no reason to ever carry a Hi-Lift again. The X-Jack works fine with a compressor.
PS- I've been using that same Sears battery for over a year. At first, the fit concerned me a bit. I suspected it might move around on the trail but it's been rock solid. Very happy with it.
PSS- No post in this thread is complete without a few of these: :drool::drool::drool:
:sombrero:
taco chaser
Supporting Sponsor
+1. I see absolutely no reason to ever carry a Hi-Lift again. :
Safety?? Depending on an air bag as the only support while working on or under a vehicle is similar to using a floor jack with no jack stands.
You should still carry an extra way to help support your rig, or find something to stack. Now an Xjack along with a HighLift sounds real solid along with the easy use and storage of the Xjack. Not every situation is on flat, soft ground or just a simple tire change... :)
Dave Bennett
Adventurist
Tacoma Tech Info!
Useful tech links from TTORA and elsewhere!
Recalls/Technical Service Bulltetins
Recalls:
Floor Mats: Click Here for More Info on Floor Mat Recall
TSB's (Technical Service Bulletin)
How to Handle a TSB: Info on what a TSB is and How to Handle One
Rear Leaf Spring TSB: Click Here for more info on the Leaf Spring TSB
Auto Transmissions TSB for 05+: Info on Auto Trans TSB
Engine Ticking Noise TSB: Engine Ticking Noise TSB
Tailgate Reinforcement TSB: Tailgate TSB
6-speed Manual Transmission Clutch difficult Engaging
TS-SB-0385-09
2007-2010 FJC
2005-2010 Tacoma
Actual Service Bulletins:
T-EG011-07: 05-07 Tacoma: 1GR-FE Engine Intermittent "No Start" Condition (Revised)
T-EG025-07: 05-07 Tacoma (2TR-FE): Crankshaft Oil Seal Leak
T-BO004-07: 05-07 Tacoma: Bent Rear Tail Gate
T-EG059-05: 05-06 Tacoma: M.I.L. "ON" DTC P0171, P0174, P2195, or P2197
T-EG046-06: 05-06 Tacoma (1GR-FE): Air Intake Hose Rattle
T-EG025-06: 05-06 Tacoma: M.I.L. "ON" DTC P043E, P043F, P2401, P2402, & P2419
T-EG021-06: 05-06 Tacoma: Exhaust Ticking Noise
T-TC006-06: 05-06 Tacoma: Clutch Pedal Feel Improvement
T-TC004-06: 05-06 Tacoma: Clutch Pedal Squeak Noise
T-BO022-06: 05-06 Tacoma: Driver's Side Dash Lower Panel Poor Fit
T-AI-0617-W: 06-08 Tacoma TVIP V5 RS3200 PLUS Owners Guide Rev. A
Common Issues/Problems:
Issues with Balancing Tires:
Balancing Wheels/Tires (Hub/Lug Centric Debate) Link
Gas Mileage Issues/Problems and Questions
There are a lot of threads that have been started on this topic, seems like there is a new one every week, so if you are having a issue with this please read these threads first then post in one of these threads (we don't need to create anymore duplicate threads on this topic)
Gas Mileage Thread 1
Gas Mileage Thread 2
Having an Issue with Post Lift Vibrations? Try These Links:
Post Lift Vib Link 1
Post Lift Vib Link 2
Post Lift Vib Link 3
Post Lift Vib Link 4
Post Lift Vib Link 5
Cracked Frame – Motor Mount Failure
Motor Mount Failure Link 1
Motor Mount Failure Link 2
Air Bag Light Is ON, Why?
Air Bag Light Link
Failed Support for Composite Bed
Bed Support Cracked Link
6spd Manual Trans Issues
Grinding While Shifting Link
6spd Manual Trans “Chirping Noise Issue” AKA Throwout Bearing
TTORA Link to Chirping Noise
Tacoma World Chirping Noise Link
Rear End Failures
Rear End Failure Link 1
Rear End Failure Link 2
Wheel Bearing / Idler Pulleys Failures
Wheel Bearing and Idler Pulley Link 1
Wheel Bearing Link 2
Suspect Water In Oil? Funky Residue in Filler Neck
Moisture Residue In Oil Filler Neck Link
How to Replace CV Axels
Directions with Pics on How to Replace a CV Axle
Common Truck Modifications:
Need Help Picking a Lift?
Questions and links for suspensions - click here
Tire Size Options With Lift
35's and 3” Lift: 35" Tires on 3" lift Link 1
35" Tires on 3" lift Link 2
35 MT/R's 1”Lift: 35" Tires on 1" lift
36's and 3” Lift: 36" Tires on 3" lift
255/85/16: 255/85/16
TIRE AND WHEEL FITMENT GUIDE
Link To Wheel and Tire Fitment Guide
Wheel Spacers
Click Here for More Info on Wheel Spacers
2005+ Locker Mod
Click Here for More Info on Locker Mod
Diff Breather Extension
Link for extending your Diff Breather
Illuminated 4x4 Dial for '05+ Tacoma (OEM Parts $$$)
Directions for Illuminated 4x4 Dial
Traction Control (ATRAC hack) Write-up
ATRAC Hack Link
What's the Biggest Tire You Can Fit on Stock Ride Height?
Tire Size Link
Snorkel on New Gen Tacoma
Install Directions Link
Shackle Flip Mod
Shackle Flip Mod Link 1
Shackle Flip Mod Link 2
Shackle Flip Mod Link 3
Different Types of Lifts Installed
Comparing Different Lift Options for 05+
Donahoes and Deavers Install on 07
Donahoes and Dakars Install on a 05
Old Man Emu Install
Solid Axel Swap Install
Long Travel Install
What to Consider After Lifting Your Truck
After Lift Extending Bump Stop Directions
Bigger Tires Now Rub on Body Mount
Fixing Issue of Tire Rubbing on Body Mount Link 2
Torn CV Boot: Option for Replacing the Whole CV Axel
Directions on how to Install a New CV
Installing Extended Rear Brake Lines
Directions on Installing Extended Brake Lines
Adding a Crawler to a 05+
Crawler Install Directions
Sway-Bar Removal
Sway Bar Removal Link 1
Sway Bar Removal Link 2
Tire Pressure Monitoring System Bypass
TPMS Bypass Link 1
TPMS Bypass Link 2 (Toyota Nation)
What You Need to Know About Re-Gearing 05 and up
Regear 05+ Link 1
Regear 05+ Link 2
Regear 05+ Link 3
Armor (Sliders, Bumpers and Beyond)
List of Rear Bumper MFGRS: Rear Bumper List
List of Slider MFGRS: Slider List
Skid Plates
ShrockWorks Tacoma Winch Bumper
Assorted Front Bumper Pics
All-Pro Plate Front Bumper
All Pro Plate Rear Bumper
Armortech Off-road Rear Bumper
ARB Front Bumper
4xInnovation Sliders
Armortech High Clearance Rear Bumper
CBI High Clearance Rear Bumper
Tacoma Auxiliary Battery Install
AUX Battery Install Link 1
AUX Battery Install Link 2
Speedometer Recalibration After Bigger Tires
How to Recalibrate Your Speedo
Superchargers
Superchargers Link 1
Superchargers Link 2
Re-Route Exhaust
Exhaust Reroute Link
Oil Filter Recommendations
Oil Filter Guide
Common "How To" Questions:
How to reset the Maintenance Required Light:
1. Start truck
2. Make sure Odometer is set to ODO xxxxx
3. Turn key to full off position
4. Push odometer button and hold
5. turn key back to on position
6. Continue holding the odometer button
7. Dashes will appear where the mileage should be located, the dashes will then disappear one by one. Hold button tell they are all gone!
1 sec(- - - - -) 1.5sec(- - - -).. (- - -).. (- -).. (-)
When the dashes are gone the odometer will blink your current miles once, and the maintenance required light will turn off.
How To Reset the Check Engine Light:
1. Turn off truck
2. Open hood
3. Disconnect negative battery cable from terminal
4. Wait 2 minutes
5. Reconnect negative battery cable
6. Close hood
7. Start truck
8. Check engine light should be off!
Note:
The Maintenance Required Light is different than the Check Engine Light
Directions For Engaging 4LO In Your Tacoma:
1) If you have a Automatic Transmission you must be stopped and in Neutral.
2) If you have a Manual Transmission you must be stopped and the clutch must be in all the way.
Still Not Working? Have you Read your Owners Manual? Or the Info Card in the Visor? How about trying one of these?
Great Links to Toyota Nation's 05+ Resources
2005+ Tacoma Modification DIY Articles
FREE Service Guide & Vehicle History PDF Glove Box Booklet
05+ Tacoma FAQ's
TSB List for 2005+ Tacoma
Linesman1776
