Vandetta
Toolman
February progress report
I've been lazy on the update sorry about that.
Lately I've been sorting out the wiring and the accessories for comfort. I reached the stage where I need to get the floor done and start running wires. I finished the under floor storage, no pics I'll add some later but here are some pics of the low voltage wiring and switch panels I'm having made.
2 100 amp fuses for house batteries
Low voltage distribution box
A lot of times you need to make little jumpers on the relays, I used welding rod and it makes for less wires and cleaner look
welding rod clipped
Here's a shot of the billet grill, some stainless bolts and the ujor frame support make for a very aggressive look.
Dual shocks were in order, so while I was there I raised the top shock mount hole 1 1/4" to gain more bump travel, spacers to go between and some 6" bolts and now it's riding really nice
I also mounted 5 rock lights under the van, here's the front bucket lights, I used 55w Hella flood lamps, because their cheap and I won't care if they get damaged. $30 for all lights.
License plate to match
Switch panels on the operating table
The Master Machinist Dave aka Snoopy
Rear door switch
Galley switch panel on the table
Two down 1 to go, THANKS DAVE !!!!!!!!
Ronyo
air tank
Progress report :
... Viair compressor. It mounts to the body with a couple of brackets I made, it fits perfectly and it's out of the way. I also mounted the air tank to the frame behind the right tire....
Is the air tank aluminum made?
Toolman
Floor Storage Lid
Got some work done on the floor storage yesterday
I also finished the dynamat on the roof, got some insulation installed and the CB antenna. I'll post some pics later.
Toolman
Over Head Console
I got my over head console dialed in and now I'm ready to start installing some switches and covering the panels
cowboy4x4
did you by chance make a pattern /template for the overhead counsel ........ and if so any chance of sharing ?...... pretty please
Toolman
Yes, however it's way more than a simple pattern. I can help you make one if you'd like... in fact I have one ready to go to a good home.. I started making another one yesterday.
The question I have for you... are you willing to help me change my spark plugs ????
LOL !!!!!!!
Henrybrowne
