FlyingWen's 2002 Jeep Liberty KJ
adrenaline503 said:
I think its too nice. Makes me jealous.
Thanks... now we just need a garage door that is 5" taller so both vehicles can fit into the garage... right now neither one can fit into the garage! YIKES!:smilies27
FlyingWen said:
[*]sunroof/moonroof, (what's the difference?)
Nice little ride, it's so cute! Those tires are adorable :-)
The difference between a sunroof and moonroof is that a sunroof opens, and moonroof doesn't....I think.
Sunroofs pop open at the back upwards. Moon roofs do that and they can also retract just like the windows on your doors. I love mine.
FlyingWen said:
Funny... he'll post the pic and not even show me....:smileeek: LOL
I thought you had him trained better than that. :smilies27
Truck's looking great. It looks like you're all set. Now on with the adventure.
I found this online
Generally, these two terms are used interchangably, and sometimes erroneously so.
Sunroofs are opaque panels that slide rearward and open completely whereas moonroofs are tinted glass panels that flip up slightly to allow air to flow. And some (but not all) moonroofs allow you to remove the glass panel and stow it (or slide into the roof) elsewhere to open completely like a sunroof.
I also think its a marketing thing!
805gregg said:
Nice KJ, I'd love to have an ARB bumper on mine but with the diesel it's already heavy in front.
Just add some OME 927 or 790's and you'll be good to go even with the CRD, ARB, and a winch.
Add some OME CRD coils which are rated at 500 lbs compared to stock CRD which are 410 lbs, Regular gas OME heavy Duty are only 400 lbs not enough for the CRD.
Tom
absolute said:
I found this online
Hum. So you are saying...http://en.wikipedia.org/wiki/Sunroof
Apparently so long as it is glass and opens completely it is a moon roof. Otherwise everything is a sunroof including a moonroof. Blagh! Ford mucked things up.
Flashlight Mount
We all have a handful of the trusty MagLight flashlights laying around. In our case my husband has quite a few laying around in the closets, vehicles, and storage containers. Many of us have one in our Jeep's, and for what ever reason the MagLight mount never seems to last. Well, the stock MagLight mount finally broke on my KJ (installed by the prior owner), and so it was time for the proper mount to be installed.
To mount the MagLight, in my case a three D cell flashlight, I used a set of QuickFist Clamps on the side of the driver's seat mounts. Here's a quick write up:
Install Time: Aprox 5 min.
Tools Needed: Drill, Drill Bit, Wrench, Marker
Hardware needed: 1 pack of QuickFist Clamps, 2 #10 screws, washers, and nuts.
Step 1: Mark the location where you place the #10 screw to mount the QuickFist Clamps as seen here:
Step 2: Drill holes to accommodate the #10 Screws as seen below:
Step 3: Install #10 screws into QuickFist Clamps using the washers provided in the package.
Step 4: Install to seat mount using the washers and nuts. Be careful not to over tighten, and tighten just enough to prevent the mounts from rotating.
Step 5: Install flashlight and enjoy!!!
Note: I am sure many of you have figured this out, but to help reduce the noise of the batteries when going over bumps or washboard, we wrap each our batteries with duct tape. Start at the seam on the side, and wrap 3 times using the factory seam as reference point. Make sure that you can remove the batteries and not to over wrap them. It works like a charm!
nahuebsch
