VVTI Mod
Start with a cold engine. Unplug the battery (10 mm wrench), remove the splash plate (12mm wrench). Now we are ready to start.
1. Loosen the tensioner and remove the belt from the alternator. 14mm socket and a breaker bar
2. Remove the plugs/ground from the alternator. 10 mm wrench (may need to loosen the bracket that holds the wiring harness too)
3. Starting with the passenger side look through the wheel well and find the 14mm "bolt" that appears in the photo.
Using a couple of 12" extensions and a "U" joint and a cheater pipe remove the bolt. It is held in place with lock tight so it will need some force.
This is your bolt/ crush washer and filter. Remove the filter and insert bolt and crush washer back into block. Tighten until you fell the crush washer "give" a little.
Do the same thing to the driver's side.
Reattach the alternator to the block, reattach all the plug connectors. Put the belt back onto the Alternator pulley. FIND a Diagram! Don't be like me and slip the belt over the top idler pulley (it runs but has bad coolant flow and no AC). Reattach the battery.
Bolt up the splash pan and your good.
Note: If you do this with an AFE air filter, the air box mod and spark plugs you will notice that it runs smoother and might give you a little more "mppphhh" off the line. It also reduces the diesel rattle that Toyota built into these trucks. You will be able to hear the VVTi kick in at mid throttle now. You have unplugged the ECU for an hour or so, it will need to reset itself which takes a 1/2 tank of gas to do.
