Land Rover Ideas for Grenadiers
I came across this ARB spare tire tie down strap in an issue of Land Rover Monthly:
I guess this isn't technically a Land Rover Idea for A Grenadier, but since I found the idea in a Land Rover magazine I'll post it here.
I carry an extra spare on my roof rack on many expeditions and I secure it with a stud that bolts to the rack. A y-strap seems like a simpler way to do it, so I decided to make a similar strap.
I looked for detail photos of the ARB strap but not finding any I found a similar product from Rhino Rack and there were good detail photos on etrailer.com.
Making one takes one ratchet strap (Home Depot: https://www.homedepot.com/p/Husky-15-ft-x-1-in-Ratchet-Tie-Down-Strap-with-S-Hook-FH0867/312994491) and one ring (Michaels, a pack of 4: https://www.michaels.com/product/antique-brass-round-rings-by-artminds-10632125), and two cam buckles (from Harbor Freight Cam Buckle Tie Downs: https://www.harborfreight.com/set-of-4-6-ft-x-1-inch-combo-tie-downs-47727.html). Total is about $20. Add one more ratchet strap and another can be made because there will be 3 rings and two HF tie downs left over after making the first one. The Rhino product sells for about $50 on etrailer.com (https://www.etrailer.com/Accessories-and-Parts/Rhino-Rack/RRRSWS.html), so you can make and extra for less than half the price of the Rhino strap and give one to a friend.
The webbing that came with the HF tie downs was thicker than the webbing from the Home Depot ratchet, so I used the HF webbing. I also used the hook from the HF straps because they were a little larger. I unsewed the stitching holding the HF straps together to avoid cutting the ends off, this maximized the length of orange webbing available for use.
A sewing machine is required to sew the loops that hold the cam buckles and ratchet to the ring but any sewing machine should be able to sew through the two layers of webbing.
Here's the completed assembly compared to the Rhino version:
The full strap:
Securing a tire to the rack:
You may have noticed one improvement over the Rhino version that can be seen in these photos: I added short lengths of Velcro I had in my scrap box to secure the loose ends of the straps. I sewed it so it can slide along the webbing to be positioned where needed. Details of the Velcro:
Here's why I did that, this is another photo from the etrailer web site. Seems like the wrapped loose ends would always be working loose at speed.
It's a pretty quick project, a huge savings from a commercial version plus it's got the Velcro improvement.
Also works nicely if I want to carry a spare on the tongue of the trailer.
This item was in Land Rover Owner:
My immediate response: That's a lot of sand in the cyclonic filter that the regular air filter doesn't have to deal with.
Probably not easy to adapt to the Grenadier factory snorkel though.
Came across this photo in one of the magazines, hadn't seen a canopy/awning/whatever like it before:
Not sure if I'd use one like that, but the slant on it reminded me of something I saw at Walmart recently:
Seems like that tent would integrate well with almost any awning mounted to the side or rear of a vehicle and make for a nice base camp you could leave set up and drive away from. The tent: https://www.walmart.com/ip/Ozark-Tr...-Canopy-Tent-Canopy-Sold-Separately/460806076
And speaking of awnings (and an awning connected to the tent above), for more weather protection, some of these might be good as side walls (https://www.walmart.com/ip/Ozark-Tr...zer-Pockets-for-Straight-leg-Canopy/495552727):
I haven't seen anything like this before (from Land Rover Owner):
Seems like rollers on a rack would be great for loading things like kayaks. Might be good for me too, I install my RTT singlehandedly and having rollers like that might make one-person installation of a roof top tent even easier, this is how I install my RTT on my Wrangler and my Grenadier...
The Home-Depot redneck version is a piece of PVC around a normal Yakima round bar :) Works great for my double sit on top ocean kayak
That's a very good idea but unfortunately it won't work with my Garvin rack basket, there's no way to slip a piece of PVC pipe over any part of it.
It's not uncommon to see photos in the Land Rover magazines of Defenders with two spares on the back:
I don't think I've seen that for a Grenadier yet. Something like it is available in Australia for Jeeps(https://www.outbackequipment.com.au/twin-rear-spare-wheel-carrier-to-suit-jeep-wrangle)
I usually carry two spares on off-road expeditions, not because I expect two flats, but because I don't want to interrupt my plans to get a tire fixed or buy a new tire. With two spares I can keep to my plan if a tire gets damaged; with only one spare I'd have to solve the problem before continuing. With my Jeeps, usually I carry the spare up top (I posted a photo of one of my Jeeps at the Arctic Circle with a spare on top a few days ago).
I would like to carry an extra spare on some expeditions with my Grenadier. If I'm not carrying the roof top tent I can put an extra spare on top like on the Wrangler but if I do have the tent there really isn't enough extra room up there for a spare so I'll have to figure something out.
Also, I don't have a second spare for my Grenadier yet. I've been looking but haven't found anything reasonably close or reasonably priced.
In the early days, camping used to be a ground tent and a Coleman stove. Then came roof top tents, then you had to have a fridge. Now maybe a complete kitchen with running water in the back of the Jeep like the MORryde Trail Kitchen. What's next, an oven?
Maybe so, this was in an issue of Land Rover Owner:
In another issue is an article about a Disco 3 with a slightly smaller oven than the one above. He's removed the third row seats and replaced it with a bulkhead that includes a second battery (for the oven and fridge), a dual battery charge controller, solar controller and a 2000kw inverter.
Mmmm... fresh baked pies at the camp site?
What's the factory bolt pattern and offset on a Grenadier? I would think that there would be a junkyard option!
It's a six bolt pattern that's the same as the Sprinter. The offset is slightly different but Sprinter wheels definitely can work as spares.
Today's Land Rover idea for a Grenadier - stronger body panels?
In the first photo in my last post, the owner of the featured vehicle is pictured standing on the bonnet (hood) of his Defender. Anyone want to try that with their Grenadier hood? Definitely not me. Photos of people standing or sitting on their Land Rover appear all the time in the magazines, I guess the Land Rover body panels are stronger than Grenadier panels?
Almost every issue of both of the Land Rover magazines I subscribe to has one or more photos of people standing or sitting on their Land Rovers.
I came across this product from Stray Systems, an Australian company that does a few accessories for Land Rovers and some other vehicles. They have a very small product line, focused on 4wd vehicles, fishing and hunting. This is part of how they describe themselves:
We have a small, bordering intimate, sample studio in Darwin, Northern Territory where we design, sample, test and iterate. We have enough capacity to do small batch runs, proud of our Australian manufacturing heritage.
One of the products currently on their web site they call a "Dash Pouch". Apparently it's a bag with Velcro on one side that they intent you to stick to your dash, assuming you have a matching Velcro dash pad (which they don't sell). A few photos from the site, these (in a Land Cruiser):
Since they don't sell the Velcro dash cover, I don't know where they expect you to get one but maybe it's a common thing down under.
I suppose storage on the dash that stays put might be useful, but I don't know if I'd like my dash covered with Velcro. What do you guys think?
Their web site: https://www.straysystems.com/shop/dash-pouch-a5/
Back when I first saw this item, I did an experiment making a hook and loop dash cover for the Wrangler. It actually worked pretty well.
A company called Overland Kitted sells a dash pad for the Grenadier but it's not Velcro and has a pouch in front of the driver that's not removable.
I've still got some large Velcro-compatible loop fabric here, maybe I'll experiment with something for the Grenadier dash.
We saw something similar at MOORE expo last year. Neat idea, they also make them to cover the cockpit of rigs with the roof removed.
ELShockley
