Hill Bill E.
Oath Keeper
I guess this is 'Home Brew', but using available factory parts:elkgrin:
I swapped out my drum brakes on my '99 XJ for a set of discs.
The disc brakes from a D35 ZJ will fit the Chryco 8.25 rear axle with only slight mods.
The center hole of the caliper bracket needs to be opened up a little.
I used a sanding drum on the drill press.
Other than that, you just need new bolts (8) and nylock nuts (8) to mount the caliper brackets (they are thicker than the drum brake backing plates)
Then you go from this:
To this:
Completed:
My total cost: $50 for the complete brake set up (local 'U-Pull-R-Parts') and $8 for the bolts/nuts.
$58 and a few hours work (pulling the entire housing is not required) not a bad upgrade!
To this:
Completed:
